Harbor Freight's Central Machinery 38142 13" DP
  • Harbor Freight's Central Machinery 38142 13" DP
    I recently purchased the Harbor Freight Central Machinery 38142 13" 16 speed benchtop DP after looking at the Craftsman 12", Hitachi, Ryobi, Harbor Freight, Griz, Northern Tool, and Delta. It was a replacement for my undersized 8" Grizzly. HF isn't known for their stellar quality and I was a bit apprehensive about buying it, but DPs are a fairly simple device and I've heard several good reports from other HF DP owners. At this point I'm fairly impressed, and think I'd need to spend considerably more money to do better. I really didn't notice much quality difference between the group of DPs that I compared. The 38142 is rated at 3/4hp, and has alot more power than my 8" Griz 1/2hp did, so I'm thinking the motor rating is fairly accurate. It weighs ~ 125# so is plenty stable. There's no detectable runout, and the quill travel is > 3". It runs smooth, strong, and true. My only complaint so far is that it's very tall for a bench DP...~ 42". I'm thinking about cutting ~ 3" off the post to bring the height down. It doesn't have any gizmos like laser guides, work light, or digital readouts, but seems to be strong in the basics. This DP retails for $195, but was on sale for $160, plus I had a 10% coupon that brought it down to $144. There are two HF stores in my area that both have liberal return policies, so I felt that my risk was fairly low. I didn't expect it to perform as well as it does, but there definitely are some gems mixed in with the "clutter" at HF.
    So far, so good, but I'll post an update if my impression sours over time.
    Machined steel column features rack and pinion table movement. Cast iron table is accurately gauged, tilts to 45° left or right. Precision chuck holds bit from the smallest wire gauge to the largest size with 5/8'' shank. Morse taper spindle for versatility. Adjustable depth stop and gauge included. Table and base are slotted for easy vise installation. UL listed.
    • Chuck capacity: 7/64'' to 5/8''
    • Column diameter: 2-57/64''
    • Spindle stroke: 3-1/8''
    • Motor HP: 3/4
    • Spindle Taper: MT2
    • Table size: 11-1/2'' diameter
    • Spindle Speeds: 16
    • Swing: 13-7/8''
    • Spindle RPM: 240 - 3600
    • Base size: 17-5/8'' x 10''
    • Height: 41-3/4''
    • Tool weight: 125 lbs.
    ITEM 38142-7VGA
    • Knottscott
      Knottscott commented
      Apparently the belts on my DP were pretty good, because vibration is very low. Link belts might be beneficial for those with some vibration...
      BTW, the DP continues to impress.
    • sparkeyjames
      sparkeyjames commented
      I also have this DP I purchased mine quite a bit ago say early 2007. Very nice DP. The spindle runout is very acceptable. I think I posted a review of mine back then. The only problem with putting link belts on this DP is that the pulleys are for 3/8 inch belts. This makes the link belts hard to find as everyone stocks the 1/2 inch ones but seemingly no one stocks the 3/8 inch variety. I have never done the belt upgrade and mine has considerable vibration. You can find the 3/8 on McMaster-Carr but I have not seen them anywhere for retail purchase. Plus you need more than 6 feet to cover both belt tracks and it is sold in 5 foot lengths $38.89 or by the foot $6.66 per foot.
      My review is here.
      http://www.bt3central.com/showthread.php?t=28527
    • jfuselier7@centurytel.net
      jfuselier7@centurytel.net commented
      I don't know what work you do, but I would think finding a way to lower the DP would be better than cutting,, that extra 3" comes in handy for taller projects, unless you have a floor model too?
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 01:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-29-2021, 11:18 PM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 02:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 04:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 01:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 12:20 AM
The SawdustZone Statistics
Topics: 61,734   Posts: 561,641   Members: 20,829   Active Members: 27
Welcome to our newest member, Mike Hinds.
What's Going On
There are currently 3347 users online. 0 members and 3347 guests.
