Knife marking pencil Accutrax
  • Knife marking pencil Accutrax
    Click image for larger version  Name:	accutrax.JPG Views:	0 Size:	69.1 KB ID:	842124
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the original blade and it came with a pack of 5 and like utility blades, can be reversed when too worn. Being in a knife handle, its perfect to mark with just as you'd cut a piece of paper or cardboard.
    Never needs sharpening, extend it as it wears with the blade retractor of the knife handle. Much sturdier than a mechanical pencil lead for marking on rough or uneven wood.
    Click image for larger version  Name:	P1140026.JPG Views:	0 Size:	138.5 KB ID:	842125
      twistsol commented
      I tried those a few years ago when McFeely's included a 3 pack in an order as a bonus. I'm too ham fisted for them and broke all three within a few days. Your mileage may very if you're normal. I keep .5mm mechanical pencils in the shop when I need to make fine pencil lines but usually use my left handed marking knife.
      LCHIEN commented
      Update 2/11/2024 - I looked on line, Woodpeckers still carries these. https://www.woodpeck.com/measuring/p...82&price=10-20
      Lee Valley shows not available
      Acme tools https://www.acmetools.com/accutrax-p...944098628.html
      LCHIEN commented
      2/23/2025 update, Woodpeckers no longer shows these. Neither Lee Valley or Amazon carry.
      Very hard to find.
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 01:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-29-2021, 11:18 PM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 02:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 04:57 PM
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 01:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 12:20 AM
The SawdustZone Statistics
Topics: 61,765   Posts: 561,900   Members: 20,848   Active Members: 29
Welcome to our newest member, kcwfurniture.
What's Going On
There are currently 4583 users online. 2 members and 4581 guests.
