Festool Domino Settings for Evenly Spaced Mortises
  • Festool Domino Settings for Evenly Spaced Mortises
    I was in the shop this weekend and was trying to figure out the math for the settings on the Festool Domino to space the mortices evenly and centered across a cabinet front to back. After a bunch of trial and error with my math, I gave up and got close enough and cut the Domino slots for most of the cabinets before my shop time ran out. It was still bugging me, so I figured it out on the plane on the way to work.
    Very simply, we need to subtract the width of all mortises created from the width of the workpiece and divide what's left by the number of spaces we will have between the mortises. Of course, there are some complications to this method that need to be resolved.
    1. When you use the paddle stop on the Domino for the first mortise, the distance between the edge of the workpiece and the first mortise will be different from the distance between the remaining mortises.
    2. When using the paddles or the cross stop, the setting on the domino shows the distances between the edge of the workpiece or previous domino and the center of the next domino to be cut, so we need to add 1/2 the width of each mortise to the setting.
    3. Mortise width is a combination of the width setting on the Domino and which cutter is installed.
    4. There is a "no man's land" of settings between the built-in pins/paddles on the Domino and the cross stop. The lowest setting on the cross stop is 100mm or about 4".
    What you'll need to know to start
    B = Domino cutter bit diameter. These range from 4mm to 14mm depending on the model of Domino joiner you own.
    S = Setting on the domino jointer. There are three options on the DF500 which are 13mm, 19mm, and 23mm. The DF700 has two options 13.5mm and 16.5mm.
    L = Length of the run you want the Dominos spread across
    M = Number of dominos you want in the length
    P = Pin/Paddle setting for the first domino. On the DF500 this is fixed at 37mm on the DF700, there are three options which are 20mm, 37mm, and 50mm
    Stuff to Calculate
    W = Mortise width created by the Domino. Determine W. Which is the mortise width created by the domino. This will be the width setting on the Domino Joiner + the diameter of the bit or W = B + S
    Looking at the diagram below, you can see that center portion in yellow comes from width setting on the Domino and represents the swing of the bit center to center. the total width of the mortise then adds the radius of the bit on each end.
    Click image for larger version  Name:	domino.jpg Views:	1 Size:	13.7 KB ID:	832621
    This diagram assumes a 5mm cutter with the width setting at medium on a DF500
    O = Offset from the edge of the workpiece to the far edge of the first mortise. There are two options you can use when starting the run of mortises
    1. Use the built-in paddle at one of the three settings which sets your first mortise centered at 20, 37, or 50 millimeters from the edge. Determine the distance from the edge of the workpiece to the far edge of the first mortise which will be your paddle offset + 1/2 of the mortise width. O = P + (W/2)
    2. Use the setting on the cross stop for all of the mortises which sets the first mortise the same distance from the edge as the distance between all the mortises. In this case, O drops out of the formula so there is no need to calculate it.
    Now we're finally ready to calculate the setting on the Domino itself. Note that if you get a value less than 100mm or you need to reduce the number of dominos or if the setting is > the max setting on the cross stop you will need to increase the number of dominos being used.
    If you are using one of the built-in pins/paddles as a starting point.
    Cross Stop Setting = (L-(O*2+W*M))/(M-1) +W/2
    Using the cross stop setting to start your first mortise rather than the paddle only changes the number of spaces between mortises which is accomplished by adding a mortise spacing on either end rather than subtracting one and ignoring the offset.
    Cross Stop Setting = (L-(W*M))/(M+1) +W/2
    Finally, the cross stop setting is in whole millimeters and you might end up with a decimal in the cross stop setting. Round this down. If you are trying to make truly symmetrical parts, then start half the mortises from one edge and the other half from the opposite edge.
    Below is an example using both methods.
    Bit Size B 5
    Mortise Width Setting S 19
    Length L 608
    Mortises M 4
    Pin/Paddle P 37
    Edge Gap with paddle O 25 P-((S+B)/2)
    Mortise Width W 24 S+B
    Cross Stop Setting no paddle 114.4 (L-(W*M))/(M+1) +W/2
    Cross Stop Setting with paddle 166 (L-(O*2+W*M))/(M-1) +W/2
      leehljp commented
      I haven't done that since college! Geometry and eyeballing go hand in hand for me, in a natural sort of state. But Algebraic configurations befuddles me now.
      capncarl commented
      I am amazed at what you can do with a Festool Domino! I have to admit that my Domino 500 kicks my butt on a regular basis. It makes me be on my “A” game every time I use it. One slip up and I’ve bored a nice oval hole in the wrong end of my board and totally messed up something. In school I was a C+ math student and my math skills didn’t get much better in the 48 years since I graduated! I haven’t found the need to install perfectly spaced dominos as described by twistsol..... although I have installed dominos in cabinet carcas to faces. I simply marked what looked like even spacing on the cabinet with a pencil and cut the slots by using the domino center line mark.
    • cphelps
      cphelps
      commented
      I rewrote this to be more clear, because I didn't understand it when I reread it.
    Posting comments is disabled.
Latest Articles
  • Pin Locked Joinery
    by Jim Frye
    This method is intended to replace nails, screws, and other metal fasteners in almost any type of wood joinery. The material is inexpensive and readily available in any grocery store. Simple hand tools are all that is needed to lock a wood joint and keep it from separating from use or age. The pins are bamboo kabob skewers and they typically run 1/8" to 5/32" in diameter making them a perfect size for wood joinery. Bamboo has straight, tough grain that is very resistant to shear forces....
    04-18-2025, 12:57 PM
  • How to set router bit and blade cut height accurately
    by LCHIEN
    How to set Bit and or blade height using various methods.
    By Loring Chien
    Oct 20, 2024
    Someone remarked how they had a hard time setting bit heights. Here is a brief tutorial on several ways and the best way I have found.
    The classic way is to use a ruler and measure the tip of the cutting bit, as shown below:
    This is some problems, hard to see, parallax, resolution. And that the tip of the bit is not flat but pointed. The cut will be to the depth...
    10-20-2024, 10:50 PM
  • How to drill perfectly placed hole into outside corner
    by LCHIEN
    Trying to drill into a outside 90 degree corner, 45° to each side, is tough, the drill bit keeps wanting to walk off.
    You can whack a small flat on the corner.
    But here is a way I did it perfectly. Using this corner drill jig
    Using the drilling jig, One hand is enough to hold the jig while drilling. The small vertical stick touching the top of the jig is my measurement stick. I use that to set the precise reproducible location of the hole relative to the top of the workpiece....
    04-26-2024, 10:41 PM
  • How to identify a Ryobi BT3000/BT3100/Craftsman 22811 or 21829 clone saw by sight
    by LCHIEN
    So you want to buy a BT3 clone. Been out of production for a while. Shopping on Craigs list or for sale ads is hard
    You have to keep an eye out and you have to be used to spotting the appearance giveaway features of the various models... Ryobi BT3000, BT3100, Craftsman 22811 and 21829
    There are certain things that clue you in and there are many ads that don't give model numbers and have crappy photos. Search for keywords RYOBI, Precision, System are often used in ad listings and
    12-20-2022, 12:53 AM
  • How to tell plunge router bits from non-plunge router bits.
    by LCHIEN
    Do you guys know your router bits?
    Do you know how to tell a plunge bit from a non-plunge bit?
    A non plunge bit has cutters around the periphery, but not the center. It can enter grooves from the side and cut moving sideways.
    A plunge bit has cutters that go all the way to the center of the bit face. It can cut moving vertically as well as sideways.
    Above see the bar across the center as well as the two edge cutters? Without this bar, when you drive the...
    12-22-2020, 03:09 AM
    by twistsol
    Very simply, we need to subtract the width of all mortises created from...
    01-28-2018, 11:46 PM
The SawdustZone Statistics
Topics: 61,768   Posts: 561,921   Members: 20,854   Active Members: 23
Welcome to our newest member, Eztravia_US.
What's Going On
There are currently 2578 users online. 2 members and 2576 guests.
