I am in the process of restoring my cedar deck and knew that there would be a lot of sanding in the process. Rather than overwork and potentially destroy my PC Random Orbit sander, I chose to pick up a cheap HF sander--on sale for 24.99. FOr the basis of this review, I will compare to my PC 333 5" Random Orbit. The HF specs will always be listed first:
Motor: 2a vs. 2.4
No power issues. I ran this sander last night for almost 3.5 hours non stop. It got slightly warm, but nothing serious given the run cycle There is less vibration in the HF and it is about 1/2 as loud. Both are 12,000rpm.
Dust collection:
HF: Cloth Bag. PC: Solid tube/filter
Neither are particularly effective, however, the PC is slightly better
Switch:
HF: Sealed. PC: No sealed.
Overall, both use standard hook & loop paper. The HF does have a rubber pad on top, which makes it slightly more comfortable to use. The sanding bed on both is virtually the same. No perceptable difference in cord length. I'd give a slight edge to the HF in total ergonomics. The biggest drawback is the dust collection. The dust collection port is an odd oblong-oval shape which would make hooking up to a shop-vac or DC a little less convienent, unlike the PC which would use a 1 1/4 vacuum collection.
I will continue to use this and see how it holds up, but initial impressions are pretty good.
Harbor Freight 5" Random Orbit Sander
Created by:
sailor55330
- Published: 07-11-2012, 12:17 PM
- 3 comments
Categories
Article Tags
- BT3x00 (72)
- bt3000 (5)
- bt3100 (2)
- cordless (1)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by
twistsol
Summary
Channel: Tool Reviews
by
LCHIEN
by
twistsol
by
twistsol
by
LCHIEN
by
LCHIEN
The SawdustZone Statistics
Topics: 61,768
Members: 20,854
Active Members: 23
Welcome to our newest member, Eztravia_US.
What's Going On
There are currently 3448 users online. 1 members and 3447 guests.
Ok, so I've used the sander now for probably a total of 10 hours of run time sanding cedar and it's basically dead. It vibrates and sometimes turns, if you let it gather up a head of steam.
Trying to decide if it's worth driving 60 miles round trip to replace or call it good.
All in all, I change my recommendation to Light Duty Only.
Buyer beware.
