Stihl 441 w/ mtronic carb
  • Stihl 441 w/ mtronic carb
    I know chainsaws aren't exactly considered fine wood working tools but...I gotta share this.
    Took a new Stihl 441 w/mtronic carb and 25" bar and reg chain out for break in this morning. I only ran through several tanks before the weather went south. This thing is smooth and doesn't bog down. I was blocking 20" to 24" round wet cottonwoods and fir.
    I can't wait to see what kind of monster this would be after full break in and skip chain.
    • conwaygolfer
      conwaygolfer commented
      You bought a good saw. I did tree work for about 30 years and Stihl was one of my favorites among the leaders. I still have and occasionally use an 064 model. It is a brute that will cut anything in front of it.
      You should not have any trouble with yours.
      Conwaygolfer
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 01:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-29-2021, 11:18 PM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 02:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 04:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 01:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 12:20 AM
The SawdustZone Statistics
Topics: 61,750   Posts: 561,796   Members: 20,836   Active Members: 23
Welcome to our newest member, jonnyben10.
What's Going On
There are currently 3773 users online. 1 members and 3772 guests.
