Ryobi JS 480L
  • Ryobi JS 480L
    Some time ago, local HD gave me a Ryobi JS 480L as a thank you for finding a pricing error (they slapped a ryobi planer price tag on a Ridgid planer --- wish they would have given me the planer, though!).
    More recently, my daughter commissioned a woodworking job (a cradle for her doll) - so I finally had a good opportunity to use this saw.
    The saw has a handy LED light that makes work a little more visible. Newer saws have lasers - which I think are over-hyped. The LED is nice. Another useful feature is the easy blade load/removal lever. I wasn't impressed by the fact the lever is plastic. Still - the feature itself is fairly decent.
    Step 1: remove and promptly discard OEM blade. Insert a Bosch blade, or something of comparable quality. The OEM blade won't cut much. I replaced mine with a 10TPI Bosch Progressor blade.
    Step 2: Check blade for square ---
    I noticed the tool-free beveling base adjusts a little too easily (there's a quick release lever that is a little too quick to release).
    Step 3: Evaluation:
    The cradle that I'm working on is made of pine. The 4.8 AMP saw had no problem cutting away the wood (not surprising). No problem scrolling through the curves in my patterns.
    I tried a couple of straight-line cuts with the base running along a square. For a jig saw, the cuts were reasonably square --- the blade did not drift around wildly, as has been reported on other Ryobi models.
    I wasn't thrilled with the high amount of plastic on this saw, but it does not seem to interfere too much with the functionality. Should the mechanism ever break, the saw would likely end up in the trash (postage would be more than the value of the saw). The blades are easily switched out (much easier than the Bosch twist/lock mechanism). I suppose that could be a liability.
    Speed adjustment --- there's a vari-speed dial, as well as a grip-based speed adjustment that confounds me, a little. I'm mostly trying to figure out why on earth a saw has two (2) speed adjustments (the Bosch has a material adjustment dial that adjusts blade tension - which I think makes a little more sense).
    The JS 480L is certainly not a Bosch. Still, it functions reasonably well for what it was designed to do.
    I would not have paid the original MSRP ($75) for this saw. My local HD has it on clearance for $39 - which I suppose is reasonable. Naturally, I'm pleased with the price I paid (naught). More important, my daughter is pleased with her doll's new cradle.
      dbhost
      commented
      Thanks for the review. That is the kindest review of a Ryobi jig saw I have ever seen...
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 02:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-30-2021, 12:18 AM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 03:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 05:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 02:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 01:20 AM
The SawdustZone Statistics
Topics: 61,772   Posts: 561,930   Members: 20,861   Active Members: 27
Welcome to our newest member, cian.
What's Going On
There are currently 3083 users online. 2 members and 3081 guests.
