Harbor Freight Multifunction tool
  • Harbor Freight Multifunction tool
    Out of the box:
    Comes with straight cutting blade, round cutting blade, scraper, and sander.
    Pros:
    Tool body is well made, machined aluminum and heavy abs plastic. Feels much more substantial than the orange Chicago Electric tools (it's maroon)
    Double insulated.
    Easy changing of attachments (30 secs or less)
    Good documentation with full diagrams
    $35 after sale & coupon
    Cons:
    Loud--wear ear protection
    There isn't much resistance between the on/off position on the switch, but it's managable.
    Some attachments better than others
    First Use:
    I needed to cut some oak baseboard while still on the wall. Decided to try this as it was much cheaper than the $99 competitors. With the straight blade, it went through the oak baseboard like butter. Easy to control, vibration wasn't bad. I then switched to the sanding attachment which honestly, wasn't very good. This could be due to the small area and the stock sandpaper, so I'm undecided on that. I then switched to the round blade--it went through schedule 40 pvc ok, but was a little more difficult to control. I haven't tried the scraper. I did try it on some scrap drywall, and it almost cut it too quickly.
    The tool handle isn't very ergonomic, so users with smaller hands may not like it. I didn't have any trouble. I'd recommend opening the box first in store. Not having much experience, I can't really comment on the quality of the blades.
    All in all, I need to play with it some more, but it could be a contender for the gem list when compared to competitors at $100 or more.
    I've not done a real tool review, so hopefully this is helpful
    • eezlock
      eezlock commented
      HF multi-function tool
      I have that very same tool ...a single speed model and so far I like it pretty well.
      I has worked perfectly the entire time I have had it (4 or 5 months) with no problem. I use it about every time I'm in the shop and working on a project,
      especially in the sanding mode. I have found the triangular shaped sanding sheets at Lowe's (Dremel brand) and Shop brand at Big Lots, works as well or better than the HF sheets in my opinion.
      Drawbacks to this tool (1) noisy, (2) in sanding mode, blows a lot of dust
      all everything around it, I made a modified vent exhaust to blow the air forward
      instead of letting it escape anywhere it wants too. (3) would like a better way
      of changing blades without using an allen wrench.
      Not a full review here on this tool for sure...just my input all the same, hope it helps someone else that is thinking about buying one in the future. eezlock
    • BigguyZ
      BigguyZ commented
      I've burned through two of these bad boys. I like it, and for $30 or so it's a great deal. However, I did recently purchase a Sonicrafter at Menards on sale. I'll say, it's a MUCH better machine. Well worth the extra $$. And, it comes with an adapter that will allow the tool to work with pretty much any other blade. Get the Tool Shop accessory set for $20, and you'll have enough blades and more than enough sand paper to last.
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 02:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-30-2021, 12:18 AM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 03:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 05:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 02:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 01:20 AM
The SawdustZone Statistics
Topics: 61,768   Posts: 561,919   Members: 20,854   Active Members: 22
Welcome to our newest member, M3lR52.
What's Going On
There are currently 6650 users online. 0 members and 6650 guests.
