I've been eyeballing the Ryobi BGH616 for a while as my old Ace Hardware 6" grinder has been making some funny noises, and the shop built tool rests on it were simply not doing the job...
I needed a grinder for various sharpening, and metals dressing tasks in the shop, and had been reading the professional comparions between bench grinders from bigger name brands such as Delta, Grizzly, Jet, DeWalt and others. And feature for feature, the field was reduced to 2 candidates, the Delta GR275, and the Ryobi BGH616. I specifically wanted a 6" grinder, in all honesty because I have a mess of grinder wheels left over from the old Ace Hardware grinder...
The Ryobi was chosen as the hands down winner due to its much lower cost.
The good.
#1. Low profile motor housing, grinding at a right angle to the motor, say sharpening a mower blade, is not only possible, but simple with this setup. (Yeah, I checked with an old blade.)
#2. Individual work lights over each wheel that pour light right onto the area you are working. The amount of light and aim of these thing so far has shown to be great. Very happy with this feature!
#3. Easily adjustable tool rests.
#4. Rubber isolation mounts to at least reduce the vibration transferred to the work bench.
#5. Magnifier lens / eye shield over the left tool rest. This really helps in getting a close up view of what you are working on!
#6. Soft start to the motor. The old Ace Hardware grinder kind of banged it's way up to almost instant speed, and took forever to stop once turned off. This grinder spins up smoothly and spins down quickly.
The Bad.
#1. 2.1 amp motor. Not exactly a power house. However there is plenty of power on tap for any grinding tasks I have thrown at it so far.
#2. I bought mine on a Black Friday door buster sale, and it appears that Ryobi rushed a bunch of these through production at the last minute, the paint on the base wasn't even completely dry. I am hoping that this is the only quality control issue that I have with this.
Overall, I am happy with the purchase, time will tell how happy...
Categories
Article Tags
- BT3x00 (72)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- sanding block (1)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by
twistsol
Summary
Channel: Tool Reviews
by
LCHIEN
by
twistsol
by
twistsol
by
LCHIEN
by
LCHIEN
The SawdustZone Statistics
Topics: 61,768
Members: 20,858
Active Members: 25
Welcome to our newest member, danny.
What's Going On
There are currently 5119 users online. 0 members and 5119 guests.
dbhost commented
FWIW, I have sold off the BGH-616, and upgraded to a BGH-827. As happy with that as the 616, but with a much bigger stone. It ran smooth as butter until I swapped in some Norton white oxide stones. I need to true these up, but funds are a little tight. I will be adding a Geiger's Dressing tool to my arsenal, the crazy dressing tool costs almost twice what the grinder cost! I sure wish that Norton would have shipped the wheels true and round!
