Jet Hybrid Table Saw
  • Jet Hybrid Table Saw
    Replaced my 20+ yr old Craftsman with the Jet ProShop Hybrid about 6 months ago. Finished my first big project - built in closet system for our master bedroom. Saw works great, and at $600 +/- it is a great value. Have a very small (20x20) garage, so opted for the Jet mobile base, too. Dust collection isn't the best, but the fence is fabulous and the alignments appear spot on use after use. The included miter gauge is not great ... use one of my Incra miter gauges depending on the activity.The stamped steel wings aren't the best at getting to parallel with the cast iron saw table...just ordered two cast iron wings online at the Jet site (thru WMhTool), anxious to get them installed.When I ordered the saw from Amazon, the cast iron wing version availability was indeterminate, so opted for this version. If you can get confirmed delivery on the cast iron version this is the one I would recommend.
    • mskono
      mskono commented
      zero clearance insert / throat plate
      I had the same issue but made a bunch up at once. I took some 1/8 hardboard and made a sandwich, cut the profile on my bandsaw loosely the used the router table / factory insert to get the shape just right. Then again with the router table to notch the rabbet. It works fine, I made about 5-6 up in one session, have them all done.
      I noticed the issue with the fence along with some deflection in the rear of the fence when you lock it down. Some adjustments and close attention when locking it, I have had no issues.
      It is a great saw for the $$$.
    • 43Hobson
      43Hobson commented
      good review
      I haven't seen it yet, but I'm hearing good things about this new Jet. I would also rather have a riving knife instead of a splitter, but everything else about this one seems on-target. Thanks for the review.
    • mskono
      mskono commented
      riving knife for jet hybrid
      This saw won't accept a riving knife because the splitter is fixed to the cabinet and doesn't move up/down with the saw blade.
      A riving knife would be a great add on if possible, I find the splitter to be fine for any thru-cuts, which is the majority of usage I have, anyway.
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 02:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-30-2021, 12:18 AM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 03:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 05:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 02:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 01:20 AM
The SawdustZone Statistics
Topics: 61,772   Posts: 561,930   Members: 20,862   Active Members: 27
Welcome to our newest member, cian.
What's Going On
There are currently 4411 users online. 2 members and 4409 guests.
