Ryobi BTS-21 10" Table Saw Long Term review.
  • Ryobi BTS-21 10" Table Saw Long Term review.
    Not years since purchase, but 10 months of fairly active use, I can honestly say I have a good feel for what the BTS-21 can, and cannot do well. So let's get down to business.
    The good.
    #1. Folding stand with wheels makes getting this thing out of the way a breeze.
    #2. Outfeed Extension works well for intermediate size pieces, needs more for large pieces.
    #3. Sliding Miter table makes miter cuts fast, accurate, and easy.
    #4. Built in dust collection shroud around blade in housing makes connecting to a shop vac dust collector easy.
    #5. Sturdy, accurate fence locks front and rear rails and holds on tight.
    #6. Cord wrap keeps the cord out of the way when not in use.
    #7. On board tool / accessory storage. This saw has nice slots for the fence, miter fence, extra blades, and blade wrenches.
    #8. Generous 27" rip capacity.
    #9. Reasonably good stock general purpose blade.
    #10. Light enough weight to make loading and unloading into a truck easy.
    #11. Alignments stable through lots of knocking around and moving.
    #12. Very accurate cuts. As long as the operator doesn't screw up that is... I recently ripped 2x4 lumber, 8 feet in length to 1.25" square (2 pieces) for a mobile base project, and my stock ended up 1.25" the entire length. This requires a steady hand though, it is really easy to kick the stock sideways and get the balde bound up.
    The bad.
    #1. Complete lack of a miter slot, or ability to easily add a miter slot.
    #2. Lack of ability to add extension rails or other accessories like the BT3x00 series has to offer.
    #3. Open housing bottom, back, combined with the guard design make for relatively poor dust collection. Better than most in this category of saw, but still pretty lousy.
    #4. Far fewer expansion options compared to the BT3x00 series.
    #5. Direct drive not as smooth as belt drive.
    #6. Arbor limits the dado stack that can be used to 5/8".
    For the type of saw this is, it has been amazingly accurate, keeps its settings, and puts up with being tossed in the back of a truck and hauled around to job sites. I have used my saw as my shop table saw, as well as hauled it around to a couple of friend's homes to make quick work of ripping and cross cutting a variety of materials for siding and deck projects.
    If you absolutely have to have a new table saw, portability is important, and your budget is under $250.00, you will want to wait for this saw to go on sale. It is a good little saw. But it has its limitations. I would consider the Ryboi BT3100 to be a superior saw in nearly all regards except for portability. If portability and new aren't important, find a lovingly used BT and be happy with it...
    • Chris S
      Chris S commented
      I recently purchased the Craftsman clone of the BTS 21. I did a lot of research before hand, so I made and informed purchase. I've only had it a few days, so I am going to try to keep this updated with what types of things I've accomplished with the saw.
      First impression:
      When I unfolded this thing, I was first impressed by the stability of the legs. The one in the store was wobbly, because it was missing the adjustable foot. After researching this saw, I learned that many people are happy with the stability, and so am I. I am a little nervous about the little adjustable foot. It works really well now, but I can see it breaking if you are not careful.
      Out of the box, it's pretty accurate. I checked everything with a framing square only, and I am getting quite accurate cuts.
      The extendable outfeed support is nice. When ripping 8 ft. 2x material, I needed no addition support. I did however use a saw horse when I ripped a 4x4.
      I'm not sure about this SMT. I cannot eye-ball it and get a good 90 degree angle. The cross cutting that I've done, I've used a framing square to get accurate cuts.
      Things I've cut:
      Ripped 8' pine 2x4's very accurately. I ripped them in half and ripped them in 1" strips.
      Made a bunch of push sticks out of 1x material
      Ripped a bunch of OSB into 24" and 16" wide pieces. It's only 7/16" OSB, but it did handle 4x8 sheet goods with good stability. I never felt like it was going to tip.
      Cross cut 8' by 16" OSB with support on both sides. I cross cut a 4' piece with no support.
      Ripped and 8' PT pine 4x4. I could tell that this was taxing the motor slightly. All I did was slow my feed rate, and it did fine.
      I know all of the cuts I've talked about are basically framing/rough carpentry cuts, but I wanted to start this as soon as I got the saw and keep it updated.
      So far, I am very pleased with the saw. I really like the mobility since I do most of my work in the driveway. I will update this as I get more projects under my belt.
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 01:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-29-2021, 11:18 PM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 02:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 04:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 01:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 12:20 AM
The SawdustZone Statistics
Topics: 61,742   Posts: 561,717   Members: 20,829   Active Members: 22
Welcome to our newest member, maysaydqtech.
What's Going On
There are currently 1784 users online. 2 members and 1782 guests.
