Incra Miter 1000 Special Edition / Incra Miter Express
  • Incra Miter 1000 Special Edition / Incra Miter Express
    I suppose considering Incra's reputation this is a simple review; it's as good as everyone says. The Miter Express is a sled, and the Miter 1000 is a precise, flexible miter system that works either on the sled or by itself. The sled is solid and smooth-running, with a couple of T tracks for hold-downs and such. The Miter 1000 SE is a well-featured miter system that includes a highly configurable stop and many more features.
    The precision is where this shines. Everything about the system is made to be adjustable for your specific saw and leaves zero movement. And I really do mean zero, after just a few minutes of tweaking you have absolute precision. At the same time, everything is very smooth-running because of their use of UHMW in just the right places.
    The full kit was on sale at Rockler for $200, and I think it was well worth that and more.
    • rnelson0
      rnelson0 commented
      I have the 1000 SE. I concur, it is an excellent product. If there is any problem with the miter gauge it is that the added precision requires multiple minute adjustments. It takes a while in the beginning and then less and less every time, but it does add time. The add precision and especially consistency is worth it, IMO.
    • richz
      richz commented
      incra miter 1000se
      I just put this on an old Craftsman along with a Delta fence. Should have done this 20 years ago. The saw works great. Both the fence and the miter were major upgrades. You can't go wrong with either.
    • RmeDad
      RmeDad commented
      I had the 1000 SE on my BT, then I moved it to the TS 3660. Friday I purchased the Miter Express and I have to concur, ONE FANTASTIC SETUP!
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 01:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-29-2021, 11:18 PM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 02:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 04:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 01:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 12:20 AM
The SawdustZone Statistics
Topics: 61,737   Posts: 561,651   Members: 20,829   Active Members: 25
Welcome to our newest member, Mike Hinds.
What's Going On
There are currently 5552 users online. 2 members and 5550 guests.
