Ridgid OSS/belt sander combo
  • Ridgid OSS/belt sander combo
    http://www.ridgid.com/Tools/EB4424-Sander/
    This is a bench-top sander that is convertible between a spindle and belt. The belt is 4" by 24" and the spindles are 4" by 1/2", 3/4", 1", 1-1/2", and 2". The conversion between spindle and belt is remarkably simple and fast, unlike many other multi-purpose tools. The alignment system for the belt gives accurate alignment even after removal and replacement, which I had suspected might not work well.
    The motor has plenty of power and I was not able to stall it with a small block pressed hard against the belt. It's got a bit of vibration; not enough to obviously affect the work, but just slightly annoying. I say this as I compare it to my name-brand cast iron tools, and should point out that it's nowhere near as bad as most other cheap tools.
    The bed is aluminum, but solid enough, and has a miter slot which is smooth and straight. The bed tilts to allow angle sanding on either the belt or spindle, and has a click lock mechanism for the common angles. The lock/tilt system works very easily and reliably/repeatably clicks into the right angles. There are plenty of adjustments for squaring and leveling everything. An engineer's square and the included hex wrench allowed me to get a very high degree of accuracy. With my dial indicator I easily got to < .005" from one end of the belt platen to the other, though the platen itself has .01" of total runout across its surface. The platen was square to about the same level using an engineer square and feeler guage. This is plenty of accuracy for a small sander I think.
    There is on-board storage for all the spindles and parts. There are handles to easily carry and move the sander if needed. It's quite portable if you prefer to carry it outside for example. There is a built-in "fan" to remove dust from the spindle, though real dust collection is obviously preferable. Connected to my DC, most dust was picked up but not all. It uses vents behind the belt to capture some of the dust, but this means that some escapes from the front/side. I have added a Loc-Line nozzle to see if I can capture the rest, but haven't tested it yet. Overall though I think the collection is pretty good.
    I'm very happy with this purchase for the price. I think it will keep me from having to spend a lot more for a good sander.
      dbhost
      commented
      I've had mine for about 7 months now I guess. I agree with the vibration issue, BUT... I have mounted mine on a 3/4" ply mount board, and in turn on a tool stand / mobile base with a good bit of weight in the bottom, and it smoothes right out...
      For the money I can't imagine a better oscillating sander, but I am sure they exist somewhere...
      I got mine on sale, with a HD gift card, I think out of pocket was less than $100.00 including tax for mine... This is a great tool for the hobby woodworker...
    • Knottscott
      Knottscott commented
      I've had the same unit for about a year and a half. It's performed nicely. My only real complaint is that I'd like to see a longer belt platen. I ended up paying full price...$200.
    • 3thumbs
      3thumbs commented
      I got mine for Christmas. I am impressed with this machine, as it does the job quite well, and it cost much less than others that don't do as much.
      DM
      edit: what is this "member review" to the left? I can't manipulate it, and I didn't give this machine a low rating.
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 01:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-29-2021, 11:18 PM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 02:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 04:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 01:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 12:20 AM
The SawdustZone Statistics
Topics: 61,750   Posts: 561,791   Members: 20,836   Active Members: 23
Welcome to our newest member, jonnyben10.
What's Going On
There are currently 2431 users online. 1 members and 2430 guests.
