Out of the box review: Seems really nice. The lasers were close, but no dead on. But they were really easy to adjust to spot on. Now they cross right at the small dot I made with the point of a brad point bit. The unit has a work light, however they didn't include a bulb. No biggie I guess, but I can't say if it works well or not.
Power seems great. This unit has an adjustable speed that you just dial in. No changing pulley positions with a belt. Also a digital speed indicator. I really like that. Heck I practically never changed the speed on my old drill press cause it was a bit of a pain.
I really wavered between the 4 and 5 scores I gave it. It's hard to give it 5's since I just got it, but I've found nothing wrong as of yet.
This is a really nice unit and I wouldn't shy at all in recommending it.
Categories
Article Tags
- BT3x00 (72)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- sandpaper (1)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by
twistsol
Summary
Channel: Tool Reviews
by
LCHIEN
by
twistsol
by
twistsol
by
LCHIEN
by
LCHIEN
The SawdustZone Statistics
Topics: 61,771
Members: 20,861
Active Members: 27
Welcome to our newest member, wmstreet@mac.com.
What's Going On
There are currently 3642 users online. 0 members and 3642 guests.
I just noticed that this did not take my scores correctly and doesnt seem to let me edit.
I gave the DP 4s across the board NOT 1s
The DP operates smothly and is quiet. I also compared it to a 12" Delta model. The Delta costs $10 more and it just did not seem as nice.
