The Snap On / Blue Point AT500C short snout 1/2" dual hammer impact wrench came into my possesion directly off of the Snap On Truck back in 1991 when I was a working mechanic. This impact wrench replaced my initial Craftsman single hammer model. The adjustable torque was well able to break loose anything my half inch impact sockets were willing to take, yet had enough finesse that it has actually been useful for utility woodworking projects such as driving lag bolts into hardwoods.
For the home woodworker that occasionally spins a wrench, and needs an impact wrench to drive long lag bolts, and help remove that transmission out of the old Jeep, Barracuda, or whatever project car... Well the AT500C is most likely not money well spent. While this is a TOP NOTCH impact wrench, the support and coverage from Snap On is just not needed by the hobbyist. Not to mention most guys aren't on the Snap On dealer's route...
So spend your money in better areas, grab an Ingersoll Rand with similar specs, and spend the extra money on some band saw blades...
Categories
Article Tags
- BT3x00 (72)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- replacement (1)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by
twistsol
Summary
Channel: Tool Reviews
by
LCHIEN
by
twistsol
by
twistsol
by
LCHIEN
by
LCHIEN
The SawdustZone Statistics
Topics: 61,731
Members: 20,829
Active Members: 30
Welcome to our newest member, Mike Hinds.
What's Going On
There are currently 2401 users online. 1 members and 2400 guests.
Footer Ad
