I picked this up with a coupon and sale, thinking that $60-ish is a bargain for a belt sander. Unfortunately it has extremely limited usability because the motor is too weak and there are no square/solid faces to be found on the thing. The work support on the belt is out of square in both directions, but it is a solid piece of thick steel so bending it would be a challenge. The tiny table for the disk bends if you set a pen blank on it, so while you can adjust it to square, it won't hold with any pressure. The HF belts are bumpy and make the piece jump off the belt. There is no dust collection at all, and I had to fabricate my own from an air duct connector.
In short, you should only buy this tool if you can't afford something like the $130 Hitachi and you only need some imprecise, small sanding work.
Harbor Freight 4" belt/6" disc sander
LCHIEN
commented
01-09-2008, 11:01 AMEditing a commentThe Ryobi BD4600 and the Delta competing model sell for around $100 typical and sometimes go on sale, would be a much better use of your money for relatively solid products. -
#2BigguyZ commented01-09-2008, 11:49 AMEditing a commentI've had poor experiences with the HF 1" loop sander too. I'm thinking I'll stick with HF for the cheap hand tools, and stay away from the powered stuff...
Posting comments is disabled. -
Categories
Article Tags
- accutrax (1)
- BT3x00 (72)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by
twistsol
Summary
Channel: Tool Reviews
by
LCHIEN
by
twistsol
by
twistsol
by
LCHIEN
by
LCHIEN
The SawdustZone Statistics
Topics: 61,772
Members: 20,862
Active Members: 28
Welcome to our newest member, cian.
What's Going On
There are currently 3890 users online. 0 members and 3890 guests.
