Harbor Freight 7" jointer vs. Jet 6" jointer
  • Harbor Freight 7" jointer vs. Jet 6" jointer
    A few years ago I picked up the HF 7" rabetting jointer. With coupons and the sale price it was somewhere below $200. Assembly of this jointer is insanely horrible, with incorrect instructions and the requirement of both SAE and metric tools (on the same bolt/nut!). You really have to go through the entire assembly instructions, then compare them to what you have, then grab a beer and torch the instructions. You're gonna be here a while. Setup takes a very long time because nothing is pre-adjusted. You will have to parallel the tables (an arduous process), adjust the knives, etc etc. I also had to make a trip back to the store when the fence lock broke right off the first time I tightened it.
    Oh yeah, the fence lock. What a useless piece of crap. I was always afraid to crank it down because it feels like it will break off again, but since it only holds from one end, it never feels solid. You can't push against the fence or you'll end up with a knicked board. I wasted a lot of perfectly good wood. A jointer is your last step for a board, so expectedly it's already nearly at the required dimensions. Knick it and you're done if the dimension is critical (which it usually is of course).
    Pretty much every time I used it, I found myself annoyed and having to fiddle with something. Adjusting the tables is a huge pain. The fence...nearly unusable. I was never able to get any joy from this tool, and felt that jointers were just useless things that only experts can learn to use.
    There is no provision for dust collection, just a "chip chute" down one side. I was able to attach a large DC hood with 4" connector using double-stick tape. However since there's no intentional routing of vacuum, there is a lot of chip spray off the cutter head both against the cut and to the sides.
    Enter the Jet ($449). I was convinced by several people that I really needed to have a jointer for a project I'm working on, and I couldn't see another way to get what I needed (perfect 45 degree miters for a cabinet). The local woodworking store had a couple people who owned the Jet and a Grizzly, and both swore I would love the Jet. They guaranteed it in fact, I could bring it back.
    I ended up taking home the floor demo, it was their only one, so I can't comment on assembly. However I read the directions and looked at the cabinet, and it appears MUCH simpler than the HF. Almost everything was adjusted properly to begin with (store personnel assured me they did not adjust it, just put it on the stand to show). Tables were perfectly parallel and knives were in place. The only adjustments I needed to make were to the fence stops, and they were already within about .2 degree each. I wanted it more precise, so I spent a few minutes with a digital angle gauge and some tools. The stops are solid, the fence adjustment is fantastic, and the entire mechanism flows smoothly, unlike the HF which often had me looking for a hammer.
    A 4" dust collection fitting is provided, and it does a very good job. There is a small amount of chip spray away from the cut, but very small. After a LOT of cuts, I would say there is less than a handful. Chip collection is better with the guard in place, most of the chips that were not picked up by the DC happened during cuts without the guard.
    From the first cut, I knew I had discovered what a jointer is supposed to be. The machine is vibration-free and quiet, unlike the HF. Cuts are smooth, the motor is powerful. The fence is solid and accurate, without the possibility of pushing it out of place. I've suddenly found myself running nearly every board through the jointer just to get that perfect edge, even where it won't be visible, just because I can. Precision fit-ups are so much easier because I simply cut pieces slightly big, then take 1/64th off with a pass, test fit, and repeat as needed.
    Overall I am 100% pleased with this purchase, and I truly wish I'd done it sooner. The guy at the wood store said that the first two tools any woodworker should have are a table saw and a jointer. Now I agree with him.
    • jhart
      jhart commented
      Thanks for the review. Have had thoughts about the HF model but have never trusted HF on a piece like that. Helps make my decision.
    • CrashResq
      CrashResq commented
      I'm going to throw my two cents in. My first and only, up to recently, jointer was an OLD craftsman that I got in a swap deal. Took me a couple of weeks in research and such to figure out how to tune it, but tuned it up and it worked great for what I used it for. This fall we had a torrential rain (it was reported that we got between 7 to 10" of rain in three hours) and my basement shop flooded. I had moved everything but my jointer and 20 gal compressor out previously due to moisture and such. Old craftsman jointer was toast.
      Several weeks ago, HF was selling their 6", $249 Central Machinery (30289) for $199 and the flyer also had a 15% coupon. For $170, I took the plunge.
      Typical of all HF tools, assembly instructions were open to interpretation. I did spend approximately 6 hours assembling this tool. Another hour cleaning the anti-rust coating off... about 2 hours aligning and tuning - i.e. all day to set up. Fence is a single lock at the end, but I believe it is more solid than the 7" jointer fence that Carlos was contending with.
      I use my jointer primarily to put a flat surface on "found wood" that I resaw on my 18" Rikon bandsaw. Secondary and equally important use for me is to true up the edges of rough lumber I purchase at a local mill. In both of these areas, the HF jointer works great. It is relatively quiet and has plenty of power (so far). Dust collection could be better. I rigged up some cardboard chutes during assembly and put a DC hood with 4" coupler - it's adequate.
      All of that was said to make the point that you do get what you pay for... but think about what you are primarily going to be using the tool for. Of course I would like to have purchased the Rikon (to match the bandsaw, of course! ), but for my jointer needs, $500 was not realistic. For $170 I can true up the edges of my lumber and make flat spots on logs, therefore the 6" Central Machinery from HF gets a thumbs up from me as a good occasional use, entry level jointer.
    • Carlos
      Carlos commented
      Now that I have a lot more board-feet over the Jet jointer I thought I'd follow up with some more observations.
      I'm still extremely pleased with it. The front-mounted adjustment wheels are a real treat. The fence adjusts easily and quickly for horizontal position without losing angle setting. A small complaint about the fence is that I can't get back to 90 degrees perfectly without measuring. Now mind you, this is because I have a digital angle reader and the "not looking" result is off by .2-.3 degrees. I put on the digital guage and give the fence handle a push to get it perfect. The issue is that as you tighten the fence angle screw, it tends to push the fence slightly out of alignment. Not a big deal with the digital angle finder (and if you don't own one, get one now for this and so many other tasks). The error is small enough that I don't see it with a square.
      Another small complaint is that the base is REALLY intended to sit on the Jet base, and is neither perfectly flat nor adjustable for level. There are no feet. So the machine wobbles just a bit. I ended up putting it on the HTC 400# base (much cheaper than the Jet base, works as well, but assembly is a bit of a pain) and that cleared up the wobble. If you really don't want a mobile base, plan to put this jointer on a wood base at least.
      Functionality remains excellent, as does chip collection. The guard works very nicely, never seems to be in my way. I'm constantly using the jointer to sneak up on cuts easily and simply just to get a perfect glue face on nearly everything I do, even basic plywood stuff for around the shop. With it, I'm finding that I rarely need corner clamps any more because all wood 1/2" or thicker tends to self-square since it's perfectly flat and parallel.
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 02:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-30-2021, 12:18 AM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 03:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 05:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 02:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 01:20 AM
The SawdustZone Statistics
Topics: 61,768   Posts: 561,921   Members: 20,856   Active Members: 23
Welcome to our newest member, Eztravia_US.
What's Going On
There are currently 4001 users online. 0 members and 4001 guests.
