Sharpening Woodworking Chisels
- Created by: Sam Conder
- Published: 03-17-2015, 04:47 PM
- 1 comment
While attending a "fundamentals of woodworking" class taught by Marc Adams at the Indianapolis woodworking show a few years ago, I was most impressed with his simple yet effective method of sharpening woodworking chisels. I contacted Marc and asked him for permission to write an article for BT3Central on how to sharpen chisels using his method. As expected, Marc was very receptive to the idea of sharing one of his "secrets". His exact response to me was " Absolutely, please feel free to teach anything you learned from me." So let's dive right into this and sharpen some chisels.
Most chisels will come coated in a packing varnish to keep them from rusting. You must first remove this varnish with a rag and lacquer thinner. Next, it is an imperative first step to flatten the back of the chisel. Even though the back may look flat, it is not. The good part is that this flattening process only has to be done once in the lifetime of the chisel.
The back is flattened using a dead flat surface and pressure sensitive adhesive (PSA) sanding disks. Some people use a piece of glass or marble, but I like to use the bed of my jointer. Stick a 120 grit PSA disk to the flat surface. Next, work the back of the chisel back and forth across the sanding disk, applying moderate pressure. After 20 or so strokes, take a look at the back of the chisel. I bet you will see a low spot where the chisel was not perfectly flat. Continue until the back looks flat and there are no low spots.
Next, using the same method, progress through 220 grit, 320 grit, 400 grit, then 600 grit PSA disks. These PSA disks are available from a variety of sources including Klingspor. When you are finished with the 600 grit the back of the chisel should have a mirror finish. The purpose of this flattening process is to remove the deep scratches that go through the cutting edge of the chisel. Otherwise, the edge would look like a serrated knife if viewed under a microscope.
With the back side flat and polished, the next step is to create a fine burr off the bevel side of the chisel. To do this I use my belt sander. I install a "dull" 150 grit belt into my handheld belt sander and clamp it into my Workmate with the belt up. With the sander turned off, find the angle of the bevel by holding the chisel against the belt and rocking it back and forth until you feel it flat on the sander. Hold the chisel at this angle with the chisel skewed a bit so that the belt runs at an angle to the edge of the chisel. Keep your index and middle fingers down near the edge of the chisel but keep them clear of the belt. With your other hand, turn on the belt sander for only a second or two. It doesn't take long to create the burr. Feel for the burr along the edge of the chisel by brushing your finger down the back of the chisel. DO NOT RUN YOUR FINGER PARALEL TO THE EDGE OR YOU WILL SLICE YOUR FINGER! Repeat this process using one or two second bursts until you can feel the burr. Once the burr is established, we are ready to move on.
The final step in the process is to remove the burr leaving a razor sharp edge. I use a muslin buffing wheel chucked into my drill press. Load the buffing wheel with Emery (black) buffing compound which you should be able to find right next to the buffing wheels in hardware stores and home centers. It will only take a second or two with the bevel side of the chisel in contact with the buffing wheel to remove the burr. Never place the back side of the chisel against the buffing wheel, it might round over the edges. Once the burr falls off the chisel will be the sharpest tool in your shop so treat it as such.
For me, this is the simplest, most effective and most inexpensive method for sharpening woodworking chisels. The PSA disks, muslin wheel, and buffing compound are the only expenses and they can serve "double duty" in your shop. My thanks go to Marc Adams for teaching me this method and for allowing me to share it.Tags: None-
#1dwitzke commented03-18-2015, 09:42 AMEditing a commentOne word of caution when using this method of sharpening. Make certain that the dust chute of your sander is free of dust. If not, you may find it smoldering when you finished your sharpening. (DAMAMHIKT)
Posting comments is disabled. -
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- relay booster (1)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by LCHIENTrying to drill into a outside 90 degree corner, 45° to each side, is tough, the drill bit keeps wanting to walk off.
You can whack a small flat on the corner.
But here is a way I did it perfectly. Using this corner drill jig
Using the drilling jig, One hand is enough to hold the jig while drilling. The small board touching the top of the jig is my measurement stick. I use that to set the precise reproducible location of the hole relative to the top of the workpiece....-
Channel: Tutorials & How To
04-26-2024, 10:41 PM -
by LCHIENSo you want to buy a BT3 clone. Been out of production for a while. Shopping on Craigs list or for sale ads is hard
You have to keep an eye out and you have to be used to spotting the appearance giveaway features of the various models... Ryobi BT3000, BT3100, Craftsman 22811 and 21829
There are certain things that clue you in and there are many ads that don't give model numbers and have crappy photos. Search for keywords RYOBI, Precision, System are often used in ad listings and...-
12-20-2022, 01:53 AM -
by LCHIENDo you guys know your router bits?
Do you know how to tell a plunge bit from a non-plunge bit?
A non plunge bit has cutters around the periphery, but not the center. It can enter grooves from the side and cut moving sideways.
A plunge bit has cutters that go all the way to the center of the bit face. It can cut moving vertically as well as sideways.
Above see the bar across the center as well as the two edge cutters? Without this bar, when you drive the...-
12-22-2020, 04:09 AM -
by twistsolI was in the shop this weekend and was trying to figure out the math for the settings on the Festool Domino to space the mortices evenly and centered across a cabinet front to back. After a bunch of trial and error with my math, I gave up and got close enough and cut the Domino slots for most of the cabinets before my shop time ran out. It was still bugging me, so I figured it out on the plane on the way to work.
Very simply, we need to subtract the width of all mortises created from...-
01-29-2018, 12:46 AM -
by Sam ConderWhile attending a "fundamentals of woodworking" class taught by Marc Adams at the Indianapolis woodworking show a few years ago, I was most impressed with his simple yet effective method of sharpening woodworking chisels. I contacted Marc and asked him for permission to write an article for BT3Central on how to sharpen chisels using his method. As expected, Marc was very receptive to the idea of sharing one of his "secrets". His exact response to me was " Absolutely, please feel free to teach anything you learned from me." So let's dive right into this and sharpen some chisels.
04-29-2015, 10:15 AM -
by LCHIENMost common places to use air fittings in a home shop:
Air compressor to hose or female QD fitting
QD female fitting or male stud to hose
male stud to tool (such as - air nozzle, nailer, screwdriver/drill/impact driver etc, spray painter)
any semi-permanent 1/4" NPT to 1/4" NPT fitting
To add to the confusion, there's nothing on a 1/4" NPT that really measures 1/4". THe threads are visibly tapered and the overall outside size of the male NPT...-
04-29-2015, 10:14 AM -
The SawdustZone Statistics
Topics: 61,299
Members: 20,639
Active Members: 69
Welcome to our newest member, AnnmarieSa.
What's Going On
There are currently 4731 users online. 6 members and 4725 guests.
Most users ever online was 15,771 at 02:28 PM on 04-26-2024.
Footer Ad
