Peachtree #369 50' 2.5" Heavy Duty Clear PVC Dust Collection Hose.
Quick review of the hose.
Good and flexible PVC material follows handheld tools like sanders super easy. Wire wrapped soft PVC is entirely too crushable. Be careful not to step on, or drop anything onto the hose!
50 foot bulk box of hose is a lifesaver for those of us wanting to make custom length hoses. I made 1 @ 20 feet, and 3 @ 10 feet out of mine.
This was the least expensive hose I could find, which is NOT why I bought it. I wanted hose that I could make a 20 footer out of without splicing.
I am a little concerned about the durability of the material it is made from though. I was able to cut through it with a utility knife, but it took way more effort to poke through than I expected (and I jabbed my finger in the process, OUCH!). The wire wrapping should make grounding the system easier as well.
Summary, so far so good. Relatively easy to work with, low cost, desirable lengths, good visibility through it to find and work out obstructions. Concerns with crushing and durability. Perhaps unfounded, but still there. Overall, I think for the cost, if these hoses last me 5 years, I will be happy with them.
RELATED REVIEW: See my review on the Peachtree #447 Screw End 2.5" Dust Collection Hose Adapters. When combined, they make a good hose assembly.Posting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- cordless (1)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,291
Members: 20,635
Active Members: 67
Welcome to our newest member, FayeBouche.
What's Going On
There are currently 11035 users online. 4 members and 11031 guests.
Most users ever online was 14,350 at 01:08 PM on Today.
Footer Ad
dbhost commented
After several months of ownership, I am finding that when left plugged into the blast gates, the hose tends to pull itself out of round, and slips off the coupler. This may end up requiring a hose clamp to get it to stay. A bit annoying, but so far, still pleased. I have stepped on the hoses, and dropped sheet goods on it, and it always bounces right back.
