Edge jointing large stock with a router.
  • Edge jointing large stock with a router.
    There has been much discussion about how to joint with a router. The often made assumption is that one does not have a jointer, thus requires use of a router for this task. I do have a jointer, but still edge joint with a router for long boards. I find it easier to control, and sometimes quicker. Moving large or long stock over a 6" jointer isn't always an accurate process.
    My method involves 4 items.
    - A router - doesn't really matter what one, but runnout is a concern here.
    - A flush trim router bit - a shear angle or spiral for curly stock.
    - A pattern bit - for wide stock, as explained below.
    - A straight edge - to guide the bearing of the above 2 bits.
    My router of choice is the Bosch 1617 in the fixed base. Any router will do, one with DC is a good choice for obvious reasons. The key to this technique is having a nice straight edge to follow. I use a MDF shelf from the BORG. The reasoning is that it was cheap (5$), reliably straight (factory sliced), and 8' long. This shelf is also 1' wide.
    The next step is to determine if the guide should be on the top or on the bottom. One nice aspect of using it on top is that the weight of it helps to flatten out the board if there is a little waver to it. Also you will be clamping the edge onto it, and it will act as a caul to this end. I will use the guide on the bottom when the board to be jointed is not very wide, or is of a material that will require me to use a spiral cutter.
    When the MDF is on top, I use a pattern bit, which has the bearing near the shank, when on the bottom I use a flush trim bit. The first photo below is the shear angle flush trim that is used for less than straight grained materials. For seriously curly materials I use a spiral flush trim, though I avoid it if possible as those bits tend to be pricey.
    As you can see in the 2nd photo, I expose as small an amount of material along one edge as possible, while having it exposed along the entire run of the straight edge. I then clamp it into place in several locations. Once done, rout between the clamps, cutting the material there straight. Then move the clamps one at a time, keeping registration to the MDF, and rout the parts missed in the first pass.
    Once this is done, you can edge glue these boards together. One additional consideration is that the router bit will likely not be a perfect 90 degrees to the base. To compensate for this error, rout one board face down, then next face up, alternating as you go. This will cause this error to be mathematically eliminated.
    I hope this is helpful.
    Keith
    • gsmittle
      gsmittle commented
      What about using one of those bits with a bearing on the top and bottom?
      g.
    • herb fellows
      herb fellows commented
      Thanks, I was guessing digital control.
    • partialresponse
      partialresponse commented
      Very helpful description of this technique. I will try it!
      Many thanks for sharing.
      Kofi
    Posting comments is disabled.
Latest Articles
  • Pin Locked Joinery
    by Jim Frye
    This method is intended to replace nails, screws, and other metal fasteners in almost any type of wood joinery. The material is inexpensive and readily available in any grocery store. Simple hand tools are all that is needed to lock a wood joint and keep it from separating from use or age. The pins are bamboo kabob skewers and they typically run 1/8" to 5/32" in diameter making them a perfect size for wood joinery. Bamboo has straight, tough grain that is very resistant to shear forces....
    04-18-2025, 12:57 PM
  • How to set router bit and blade cut height accurately
    by LCHIEN
    How to set Bit and or blade height using various methods.
    By Loring Chien
    Oct 20, 2024
    Someone remarked how they had a hard time setting bit heights. Here is a brief tutorial on several ways and the best way I have found.
    The classic way is to use a ruler and measure the tip of the cutting bit, as shown below:
    This is some problems, hard to see, parallax, resolution. And that the tip of the bit is not flat but pointed. The cut will be to the depth...
    10-20-2024, 10:50 PM
  • How to drill perfectly placed hole into outside corner
    by LCHIEN
    Trying to drill into a outside 90 degree corner, 45° to each side, is tough, the drill bit keeps wanting to walk off.
    You can whack a small flat on the corner.
    But here is a way I did it perfectly. Using this corner drill jig
    Using the drilling jig, One hand is enough to hold the jig while drilling. The small vertical stick touching the top of the jig is my measurement stick. I use that to set the precise reproducible location of the hole relative to the top of the workpiece....
    04-26-2024, 10:41 PM
  • How to identify a Ryobi BT3000/BT3100/Craftsman 22811 or 21829 clone saw by sight
    by LCHIEN
    So you want to buy a BT3 clone. Been out of production for a while. Shopping on Craigs list or for sale ads is hard
    You have to keep an eye out and you have to be used to spotting the appearance giveaway features of the various models... Ryobi BT3000, BT3100, Craftsman 22811 and 21829
    There are certain things that clue you in and there are many ads that don't give model numbers and have crappy photos. Search for keywords RYOBI, Precision, System are often used in ad listings and
    12-20-2022, 12:53 AM
  • How to tell plunge router bits from non-plunge router bits.
    by LCHIEN
    Do you guys know your router bits?
    Do you know how to tell a plunge bit from a non-plunge bit?
    A non plunge bit has cutters around the periphery, but not the center. It can enter grooves from the side and cut moving sideways.
    A plunge bit has cutters that go all the way to the center of the bit face. It can cut moving vertically as well as sideways.
    Above see the bar across the center as well as the two edge cutters? Without this bar, when you drive the...
    12-22-2020, 03:09 AM
  • Festool Domino Settings for Evenly Spaced Mortises
    by twistsol
    I was in the shop this weekend and was trying to figure out the math for the settings on the Festool Domino to space the mortices evenly and centered across a cabinet front to back. After a bunch of trial and error with my math, I gave up and got close enough and cut the Domino slots for most of the cabinets before my shop time ran out. It was still bugging me, so I figured it out on the plane on the way to work.
    Very simply, we need to subtract the width of all mortises created from...
    01-28-2018, 11:46 PM
The SawdustZone Statistics
Topics: 61,772   Posts: 561,930   Members: 20,861   Active Members: 27
Welcome to our newest member, cian.
What's Going On
There are currently 2612 users online. 2 members and 2610 guests.
