Treating veneer edges for glue up.
  • Treating veneer edges for glue up.
    I have used veneer saws in the past to cut edges for gluing together veneer, and I've compressed it between 2 pieces of 1/4" ply and cut on the TS. These work ok, but I didn't get perfect edges from the veneer saw, and I wasted a good deal of ply on the TS. I just finished a marquetry panel for a project (images soon) and when it came time to veneer, I can to face this problem again.
    For marquetry, I use shop cut veneer, so that it'll hold together while I make the double bevel cut on the scroll saw. So my veneer was 1/16" thick, far thicker than commercial veneer. I suspected that I may get away with edge jointing on my jointer, and I did for the poplar, but it was a stressful experience, half expecting the veneer to explode. When I tried this with the curly maple, it chipped out, sadly, so I tried a new (to me) way...
    I started by edge jointing 2 3/4" pieces of scrap oak that I had from a prior project, and then ripped them to equal width on the TS.
    I sat these into my workmate, jointed faces up. They span the 2 supports below, and create a level reference plane. I then slid my veneer between the two oak boards, and exposed a small amount of material, as little as I could while taking out the afore-mentioned chip out.
    Then I simply planed down the veneer with a low angle block plane. This took very little time, was stress reducing, rather than stress causing, and yielded nice straight edges that I could veneer tape together, and put into the veneer press.
    I don't know how many people will get use from this, but I hope someone gains benefit from the idea, thanks.
      Posting comments is disabled.
    Latest Articles
    • Pin Locked Joinery
      by Jim Frye
      This method is intended to replace nails, screws, and other metal fasteners in almost any type of wood joinery. The material is inexpensive and readily available in any grocery store. Simple hand tools are all that is needed to lock a wood joint and keep it from separating from use or age. The pins are bamboo kabob skewers and they typically run 1/8" to 5/32" in diameter making them a perfect size for wood joinery. Bamboo has straight, tough grain that is very resistant to shear forces....
      04-18-2025, 12:57 PM
    • How to set router bit and blade cut height accurately
      by LCHIEN
      How to set Bit and or blade height using various methods.
      By Loring Chien
      Oct 20, 2024
      Someone remarked how they had a hard time setting bit heights. Here is a brief tutorial on several ways and the best way I have found.
      The classic way is to use a ruler and measure the tip of the cutting bit, as shown below:
      This is some problems, hard to see, parallax, resolution. And that the tip of the bit is not flat but pointed. The cut will be to the depth...
      10-20-2024, 10:50 PM
    • How to drill perfectly placed hole into outside corner
      by LCHIEN
      Trying to drill into a outside 90 degree corner, 45° to each side, is tough, the drill bit keeps wanting to walk off.
      You can whack a small flat on the corner.
      But here is a way I did it perfectly. Using this corner drill jig
      Using the drilling jig, One hand is enough to hold the jig while drilling. The small vertical stick touching the top of the jig is my measurement stick. I use that to set the precise reproducible location of the hole relative to the top of the workpiece....
      04-26-2024, 10:41 PM
    • How to identify a Ryobi BT3000/BT3100/Craftsman 22811 or 21829 clone saw by sight
      by LCHIEN
      So you want to buy a BT3 clone. Been out of production for a while. Shopping on Craigs list or for sale ads is hard
      You have to keep an eye out and you have to be used to spotting the appearance giveaway features of the various models... Ryobi BT3000, BT3100, Craftsman 22811 and 21829
      There are certain things that clue you in and there are many ads that don't give model numbers and have crappy photos. Search for keywords RYOBI, Precision, System are often used in ad listings and
      12-20-2022, 12:53 AM
    • How to tell plunge router bits from non-plunge router bits.
      by LCHIEN
      Do you guys know your router bits?
      Do you know how to tell a plunge bit from a non-plunge bit?
      A non plunge bit has cutters around the periphery, but not the center. It can enter grooves from the side and cut moving sideways.
      A plunge bit has cutters that go all the way to the center of the bit face. It can cut moving vertically as well as sideways.
      Above see the bar across the center as well as the two edge cutters? Without this bar, when you drive the...
      12-22-2020, 03:09 AM
    • Festool Domino Settings for Evenly Spaced Mortises
      by twistsol
      I was in the shop this weekend and was trying to figure out the math for the settings on the Festool Domino to space the mortices evenly and centered across a cabinet front to back. After a bunch of trial and error with my math, I gave up and got close enough and cut the Domino slots for most of the cabinets before my shop time ran out. It was still bugging me, so I figured it out on the plane on the way to work.
      Very simply, we need to subtract the width of all mortises created from...
      01-28-2018, 11:46 PM
    The SawdustZone Statistics
    Topics: 61,768   Posts: 561,919   Members: 20,854   Active Members: 22
    Welcome to our newest member, M3lR52.
    What's Going On
    There are currently 3080 users online. 3 members and 3077 guests.
