HF 4-1/2" ANGLE GRINDER - ITEM 95578
  • HF 4-1/2" ANGLE GRINDER - ITEM 95578
    Not bad for under $9. Here's the bottom line. I need to cut "T-Posts" that are buried underground in three feet of concrete. (Can you say overkill?)
    Out to local HF to see what I can come up with. Found it onsale. This version comes with no wheels does have the flange washers and a spanner wrench . All you have to do is add cutoff or grinder wheel. For a few dollars more, I found a ten pack of metal cutoff wheels. Two bucks for safety glasses. For $21 with tax, I was able to quickly cut the T-Posts. Less than a minute to eat through.
    Say what you will about HF tools. I certainly got my money's worth and them some. Is it pretty and have the DeWalt name? Nope. It's a blue DrillMaster with a reversible handle. Spins the cutoff wheel at 11,000 rpm. Just let the wheel do the work and it will treat you right. No complaints with this one.
    Here's the link: http://www.harborfreight.com/cpi/cta...emnumber=95578
    • corndog
      corndog commented
      CORNDOG
      HARBOR FREIGHT, Well I must say this place is the first place I go when the need comes to purchase tools. I feel as though I'm 70 years old and have worked with tools most of my adult life I am smart enough to recognize junk and not buy it and Harbor Freight does fit the junk category SOME OF THE TIME but quite often not! So I would say to you if you can't judge for your self and it's cheap enough, what the heck give it a shot. I was very skeptical when I bought my "DRILL MASTER" 18v DRILLw/KEY LESS CHUCK AND I CAN'T KILL THE THING!! I've had it for about 3 years or so and for 17+ dollars I'm as happy as if I had bought a Dewalt or any other expensive one! I use this drill just about everyday without fear of it quitting. The charger that comes with it caused me to kill one of the batteries of 2 that I had bought extra with it because I forgot and left it charge over night,MY OWN FAULT, THEY COME WITH A WARNING! TOM{corndog}
    • corndog
      corndog commented
      STRONG SUGGESTION; I would strongly suggest to all of you that are in the market for one of these 4 1/2" angle grinders to carefully look at the selection available and choose one with a "PADDLE SWITCH" instead of just an "On/OFF" switch!!!! THIS IS FOR YOUR SAFETY, THESE GRINDERS TURN A LOT OF RPM AND SHOULD YOU GET INTO TROUBLE IT WILL SHUT OFF AS SOON AS YOU LET GO OF THE PADDLE!! THESE THINGS WILL EAT YOU UP IF GIVEN 1/2 A CHANCE AND DONT TAKE THE GUARD OFF JUST BECAUSE IT GETS IN YOUR WAY ONCE OR TWICE! ASHAMED TO SAY, I'VE PAID THE PRICE!!!!!!!!!!!!!!
    • davecaz
      #23
      davecaz commented
      I plug my charger into a cheap 24 hr timer that is designed to turn on a lamp to make your house look occupied while you are away. I have the little pegs set for 3 hrs. I spin the timer until it turns on and walk away. It will power the charger for the set time and then turn off. I then have 24 hrs to disconnect before it starts charging again. I have forgotten about it a couple of times, but I guess that 21 hrs with no power saved the battery.
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 02:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-30-2021, 12:18 AM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 03:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 05:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 02:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 01:20 AM
The SawdustZone Statistics
Topics: 61,771   Posts: 561,927   Members: 20,861   Active Members: 27
Welcome to our newest member, wmstreet@mac.com.
What's Going On
There are currently 3805 users online. 0 members and 3805 guests.
