Central Pneumatic 97526 23ga air pin nailer
  • Central Pneumatic 97526 23ga air pin nailer
    A quick rundown of the Central Pneumatic 97526 23ga pnuematic pin nailer. For starters, this IS a Harbor Freight tool. And like most Harbor Freight stuff, it is lacking some of the more refined features of more expensive tools. But at a price of $22.99 minus a 20% coupon discount, you can walk into your shop with one of these, and a fatter wallet to boot!
    Air consumption was reasonable as my little 2 HP 8 gallon compressor (Central Pneumatic 95386 easily able to keep up with the air demand of this nailer. Nail placement was fast, reliable, full and accurate. No jams, no misfires. Simply follow the directions and you are good to go.
    I have 2 complaints with this nailer though. They are...
    #1. No nose safety like what is on my other nailers. The safety is a trigger lockout mechanism. It works, but must be manually set, and unset. Basically if you treat this like a pistol, you'll be fine...
    #2. Changing pin sizes. I stored my pinner with 1” pins. When I went to change pins out, I slipped the 5/8” pins in, then tried to change the depth setting. It doesn’t work that way. I had to remove the 5/8” pins, reinsert the 1” pins, attach the air, fire a pin, detach the air, remove the 1” pins, set the depth to 5/8”, then insert the 5/8” pins… While this was my stupidity, it was not obvious on the tool that the depth should be set prior to inserting the pins, nor is it obvious in the manual. Or if it is, I must have missed it…
    Fit and finish on this pin nailer are actually quite good, with the exception of the labeling, which appears to be an afterthought. And while this nailer did not come with any sort of case, at this price point, expecting a case is a bit much. The labels stickers that they are... were reasonably well aligned, just not fully stuck down in place. In the case of my nailer, requiring the user (me) to simply rub the air bubbles out of under the sticker with my thumb nail....
    While this is not exactly a perfect tool, I can see why this pin nailer is frequently seen on the Harbor Freight Gems lists on various web sites.
    If you are in need of a good, basic pinner, and can operate safely without the safety lockout, then this is a great way to go.
    • tommyt654
      tommyt654 commented
      Got one a couple months back and it works quite well for the $16 I paid when it was on sale - 20%
      Bill in Buena Park commented
      Good review Dave. I've owned one for a few months now, and appreciate what a nice job this does with pin placement. If it's not on the "gems" list, I'd consider it a candidate.
      I believe there are other pin nailers without the nose safety, so I wasn't surprised by its absence, and just handle with more care to avoid accidental firing.
      dbhost
      commented
      It's on the gems list for sure... Nice little gun, at the rate I am using this one, I am going to wear it out! I have been pinning stuff just for the fun of it. It's kind of scary actually...
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 01:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-29-2021, 11:18 PM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 02:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 04:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 01:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 12:20 AM
The SawdustZone Statistics
Topics: 61,730   Posts: 561,621   Members: 20,829   Active Members: 31
Welcome to our newest member, Mike Hinds.
What's Going On
There are currently 2609 users online. 0 members and 2609 guests.
