Harbor Freight Electric Paint Remover Model 65990
I've been using this paint remover on my house with good results. It spins a 4.5 inch (scotch brite type material) disk. Paint & bondo are easily removed & feathered (doesn't seem to dig or gouge the wood). This tool is available internet or catalog only for $33 & $6 for replacement disks. I think this tool would be popular if it were available in the HF stores. Wagner makes a similar tool ($85 & $15 for replacement disks). Wagner claims the secret to this tool is the 2500 rpm disk speed, the paint comes off in flakes instead of a melted mess. Definitely wear mask & eye protection.Posting comments is disabled.
Categories
Article Tags
- BT3x00 (72)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- jig (1)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by
twistsol
Summary
Channel: Tool Reviews
by
LCHIEN
by
twistsol
by
twistsol
by
LCHIEN
by
LCHIEN
The SawdustZone Statistics
Topics: 61,761
Members: 20,847
Active Members: 29
Welcome to our newest member, RobertBrown9.
What's Going On
There are currently 3752 users online. 1 members and 3751 guests.
The disks sell for $14.95.
Went to my HD in Lake City, Fl, had them check the price, the Paint Eater is $79.
