HF 95275 Pancake Compressor
  • HF 95275 Pancake Compressor
    I broke the regulator off of my cheap coleman portable compressor over a year ago. Since I was unable to remove the remnants of the broken pipe with an easy-out, I wrote it off.
    Two weeks ago, I received a copy of Westways magazine from AAA. Inside was a $39.99 coupon for the Harbor Freight 95275 3 Gallon Pancake air compressor.
    It took two trips to the store to lay my hands on one, but I'm very favorably impressed. Overall this seems to a quality unit - better than the Coleman unit it replaced. The unit is fairly light and seems to be good quality. The regulator is protected by plastic housing and the overall form is quite compact. The housing includes a covered storage pocket which could hold inflation needles or a small tire chuck. It also includes provisions for cord storage.
    I did need to purchase a male quick connnect as it was not included.
    In use, my compressor to 3 mins 35 secs to completely fill the tank to 100 psi. It also drove 14 18ga staples, before it cycled.
    I'd classify this compressor as another HF gem!
      Posting comments is disabled.
    Latest Articles
    • A review of the Kreg Precision Trak & Stop Kit
      by twistsol
      Summary
      03-23-2022, 02:59 PM
    • Review of VIX-type Self Centering drill bits
      by LCHIEN
      The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
      08-30-2021, 12:18 AM
    • Grizzly Overarm Blade Guard review.
      by twistsol
      First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
      07-26-2021, 03:47 PM
    • Kreg KMA 3220 5mm Shelf Pin Jig
      by twistsol
      I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
      03-19-2021, 05:57 PM
    • Knife marking pencil Accutrax
      by LCHIEN
      Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
      01-14-2021, 02:25 AM
    • Saddle squares
      by LCHIEN
      Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
      01-13-2021, 01:20 AM
    The SawdustZone Statistics
    Topics: 61,768   Posts: 561,921   Members: 20,856   Active Members: 24
    Welcome to our newest member, Eztravia_US.
    What's Going On
    There are currently 2254 users online. 1 members and 2253 guests.
