NPS1018 Cordless Power Scrubber
http://www.blackanddecker.com/Produc...roductID=15493
This is not a woodworking tool, but might get you back in the shop faster after other chores.
I have used this new tool for three jobs.
Scrubbing down my boat. Best thing here was going after that full winter's scum and growth along the water line. I hooked up the extension to a full 14 feet and within a few minutes wiped the water line clean. Then cleaned up the boat in 45 minutes.
Washing the pickup. 15 minutes and I did not get wet!
Cleaning up our glass deck railings. No ladders, bird t*rds erased.
18 Volt battery lasted all the way through each of these jobs. Same battery and charger as our B&D weed eater.
Unit is well balanced, even with extensions I did not feel fatigued.
Using this scrubber almost makes these chores fun. Gets me back to WW quickly.
Cost ~ $100 at Walmart using ship to store.
Disappointments: Manual is inconvenient size (5X8) and came balled up with the unit although it could have laid flat in the box.
Categories
Article Tags
- BT3x00 (72)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- Sharpening (4)
- smt (1)
- t-nut (3)
- wide table kit (2)
Latest Articles
by
twistsol
Summary
Channel: Tool Reviews
by
LCHIEN
by
twistsol
by
twistsol
by
LCHIEN
by
LCHIEN
The SawdustZone Statistics
Topics: 61,768
Members: 20,858
Active Members: 25
Welcome to our newest member, danny.
What's Going On
There are currently 4117 users online. 0 members and 4117 guests.
