Sunhill helical cutterhead upgrade kit
  • Sunhill helical cutterhead upgrade kit
    I picked this up for my Jet JJ-6CSX jointer. Installation wasn't tough, but I did need to go to the auto parts store to get a pulley puller to swap the bearings. This isn't required for all jointers, but is for mine. There was no documentation to explain this (or anything), but Sunhill answered the phone and helped me quickly when I called them. I used the cutterhead R/R instructions from Jet and that was sufficient. I would say the job took one hour plus having to go get the puller.
    Cut quality with this head is phenomenal. Tear-out is nearly eliminated on cross-grain cuts, and totally eliminated on face grain. Even birdseye maple has no eye tear-outs. Cutting in the wrong direction barely decreases cut quality. Chatter and vibration are zero now.
    Although this unit is pricey ($320), the improvement in cut quality and usability is well worth it. The carbide cutters last much longer, plus have four cutting surfaces (rotate the cutters to expose a new surface). They will probably out-last several sets of HSS knives.
    • thiggy
      thiggy commented
      Well written.
    • Tom Slick
      Tom Slick commented
      Is it quieter when cutting?
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 01:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-29-2021, 11:18 PM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 02:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 04:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 01:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 12:20 AM
The SawdustZone Statistics
Topics: 61,758   Posts: 561,860   Members: 20,846   Active Members: 34
Welcome to our newest member, tabeerhomes.
What's Going On
There are currently 1560 users online. 1 members and 1559 guests.
