Drill Master (HF) 1" to 2-1/2" Hole Saw Set
  • Drill Master (HF) 1" to 2-1/2" Hole Saw Set
    I recently acquired a Drill Master 94203 1" to 2-1/2" Hole Saw Set from Harbor Freight Tools to bore some large holes after my old Ace Hardware set was discovered missing. (Long story, problem since solved). As often as I have been using a hole saw, I figured a cheapie wouldn't be a bad thing. I was wrong.
    The good.
    The steel cups are nice and straight, and if it was completely up to the cup, this would drill nice, perfectly straight holes exactly where you want them.
    The injection molded case is nice for keeping your bits and pieces organized.
    Everything you need is included, however...
    The bad.
    The set screw threads in the arbor were stripped out from the factory, making it impossible to tighten the set screw onto the pilot bit.
    The pilot bit was bent from the factory, meaning once the set screw problem was taken care of by rethreading the hole and adding a new set screw, the saw still wouldn't drill a straight hole.
    The solutions to the bad.
    Using a machine tap, rethread the hole for the set screw, and replace the set screw with the new larger size. Pick your tap size and set screw size carefully, there isn't a lot of material to work with here.
    Replace the pilot bit with a decent quality bit. I matched up the bit with a same size old mismatched Ace Hardware bit I had in a toolbox. I ground a flat spot for the set screw to tighten down to, and installed it. NOW the hole saw set works fine.
    Long and short of it, don't waste your time, unless money is really that tight, and you have a tap set handy, and even then it is a pain to deal with... You will be far better off with a better quality set...
    • alfred
      alfred commented
      Satisfaction and a Caution on threads!
      I bought the large and small sets on sale to make bird houses out of scrap pallets and other boards.I did not wish to use my name brand hole saws in used wood where I could possibly hit a nail,a staple or dull them on the sandy dirt impregnated wood as some was very dirty.I have used them from the 1" to the 5" sizes with no problems so far.Now all I have used them in is soft,measured 5/8 to 1 inch Pine and Fir.I have been very gentile in my use.So far I have not hit a knot or any metal and all is going well with them.I would buy them again for this.
      Now for HF set screws and bolts.I was going to buy some extra metric set screws to keep on hand to fit my hole saws and drill press.Also a longer bolt for the Drill Press.Ha!These are not standard metric screw threads!I bought a assortment of standard metric set screws and a bolt like fits everything else metric.No good with the Harbor Freight stuff so far.alfred
      LCHIEN commented
      i got one, too. the cups are ok but the arbors are crap for the aforementioned reasons. I ended up using an arbor I had for a single (not a set) vermont american holes saw I had, the D-hole fit perfectly, the drill bit was a different diameter.
      dbhost
      commented
      Not a bad thought. I have since snapped the shaft off of one of the arbors...
      I think I have an old VA arbor somewhere...
      Like you mention, the cups are actually fairly decent. Not great, but worth the $$ if a pinch...
      Certainly worth the cost of you can force them to work and are boring holes in questionable stock....
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 01:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-29-2021, 11:18 PM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 02:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 04:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 01:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 12:20 AM
The SawdustZone Statistics
Topics: 61,731   Posts: 561,624   Members: 20,829   Active Members: 30
Welcome to our newest member, Mike Hinds.
What's Going On
There are currently 2288 users online. 0 members and 2288 guests.
