HF Combination square set
  • HF Combination square set
    I got the Centech 4-piece combination square set HF#92471 for around 6-7 bucks. I think it was on sale for $6, a buck off the regular price. Having a decent Stanley Comb. Square, I wanted a protractor and centerfinder attachment. I figured for $6, how bad can it be?
    Came in a wooden case which it turns out was the best part.
    The fit and finish was awful. the metal was rough, the paint rough and peeling and the parts did not slide well at all. I guess the square and centerfinder move OK (locking screw was a little rough feeling), but the protractor took a superhuman effort to move (rotate) and the scale was all but unreadable, the scale was on one piece and the indicator marks on the other moving piece but they were on slightly different, non-parallel planes so the faint markings (hard to read except at a perfect incident light angle) required two perfect incident light angles to read. I.e. you can't read both at the same time. Rule Scale was stamped, not engraved, kind of low quality. At least the markings were in the correct place.
    I kept the rule with the centerfinder and tossed the protractor and the square handle. I did not even bother to check if the square was at 90°.
    The parts do interchange with other combination squares out there... the rules being simlar withthe locking groove in the same place.
    The best part was the box, I eventually bought a used Starrett 4-piece set for around $60 (current new price around $140) and I keep it in the box!
    There's no comparison to the Starrett set, which has impeccable finish and everything slides smoothly and very easy to read the engraved scales (protractor and rule). Even though the set is probably 30+ years old.
      LCHIEN commented
      well, I posted the original review over a year ago. I never said the tools were not square or accurate, just that the user satisfaction using them was extremely low.
      I don't recall ever having done any extensive testing on the accuracy or squareness.
      I'm sure they were'nt way off or anything.
    • alfred
      alfred commented
      Thanks!
      I found your info very informative and valuable to me.It reassures me in my opinion on HF's quality control or rather lack of.One time the item is great and the very next time it is often junk.This is why I inspect all in the store when possible!I also disassemble,inspect,go over,detail,correct,lube and preserve everything that I buy where feasible.I mean that I look for defects with a GOOD Magnifying Glass and even run cotton "Q"tips over metal looking for burrs.I then correct everything that I can down to the slightest detail.There are very few things you buy that you cannot improve on.alfred
      LCHIEN commented
      FWIW, its 13 years later and I',m still using the centerfinder head and rule part to mark the center of dowels and even square or near square pieces. So I guess it was a $6 centerfinder and it works very well at that.
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 02:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-30-2021, 12:18 AM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 03:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 05:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 02:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 01:20 AM
The SawdustZone Statistics
Topics: 61,768   Posts: 561,919   Members: 20,854   Active Members: 22
Welcome to our newest member, M3lR52.
What's Going On
There are currently 3765 users online. 2 members and 3763 guests.
