Basic rundown. This is not a complicated item, just a basic stand. The metal is kind of flimsy, the instructions stink just like most other HF tools. But it does what is expected of it. The user MUST use some sort of baseplate such as plywood to add rigidity, as the stand on its own, is pretty floppy. All in all worth the $19.99 on sale price, and not a penny more.
The top mount where the actual tool goes is too small to be useful for most benchtop tools without a mount board anyway... It is usable, but I think a buyer would be better off with the 46075-4VGA model instead...
Categories
Article Tags
- BT3x00 (72)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- replacement (1)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by
twistsol
Summary
Channel: Tool Reviews
by
LCHIEN
by
twistsol
by
twistsol
by
LCHIEN
by
LCHIEN
The SawdustZone Statistics
Topics: 61,767
Members: 20,851
Active Members: 28
Welcome to our newest member, jasonsky.
What's Going On
There are currently 2691 users online. 2 members and 2689 guests.
