Sears router
Created by:
tellittojake
- Published: 08-20-2007, 04:00 PM
- 5 comments
Sears router
Nice features for half the price of the higher end products. While I do think that DeWalt, PC, Milwaukee etc. are well made and worth the price they ask for the better names, I do not always have hundreds of dollars to make another purchase at any given time. The new Routers from Sears are certainly a huge step above the Skil and B&D offerings, at only a slightly higher retail. I love the soft start, PC compatable base for bushings, work light and noise level that is not as deafening as some. If you can buy a Bosch, PC, DeWalt or similiar product get one, but if you are looking for a good value and not be sorry you picked it up, check these out.Posting comments is disabled.
Categories
Article Tags
- BT3x00 (72)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- remote control (1)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by
twistsol
Summary
Channel: Tool Reviews
by
LCHIEN
by
twistsol
by
twistsol
by
LCHIEN
by
LCHIEN
The SawdustZone Statistics
Topics: 61,768
Members: 20,854
Active Members: 22
Welcome to our newest member, M3lR52.
What's Going On
There are currently 3216 users online. 3 members and 3213 guests.
Links to other reviews:
http://www.routerforums.com/table-mo...e-routing.html
http://www.routerforums.com/39447-post21.html
http://www.routerforums.com/general-...bo-review.html
Above table adjustment, 2 bases, 2+hp with VS and SS .... all for $109 sounds like an awfully good deal. If I didn't already have the Triton, 3 base DeWalt kit and Ryobi Plunger, I'd be all over this kit.
http://www.sears.com/sr/javasr/produ...TOOL&ihtoken=1
Disregard the ratings on this post.
if you go into a sears store you will see they have a few models but basically the same machinge, either a one speed fixed base, plunge version with variable speed, combo kit, etc. but basically the same machine- just as you can buy versions of a Hitachi etc.
