Steel City Mortiser
  • Steel City Mortiser
    Just ordered and recieved the Steel City Benchtop Mortiser and wanted to put a quick review of it up. It's not the cheapest mortiser around at $289 plus shipping, but it feels like a quality piece for the price. I have to admit that this is my first mortiser so that may color my views.
    To start with, it's heavy, about 90 pounds, with a very solid cast iron base and fence. The DHL guy was good enough to unload it next to the garage so I only had to drag it a few feet into the garage to set it up. Instructions are generally ok, but with a few minor errors, for example the hydraulic rod was not attached on mine, although the pics and instructions imply it should be. No worries though as it went together quite easily. The fence on mine set perfectly square, and the microadjust works as advertised.
    I started testing it with the included 3/8" chisel set which squared up quickly, and proceeded to put some mortises in 6/4 cherry stock just to see how it worked. While the chisels seem sharp enough there is some minor edge waviness so they will all need to be squared up on a stone before any real use. I'd say the chisels are about what you would expect to be included for the price, decent, but not perfect.
    The front clamps are extremely good, they are set up with rollers so that that you set the depth for the piece you are cutting and can then easily move it down to drill another mortise int he same piece. I found they worked very well for holding the lumber hard against the face without making you reset everything to cut another mortise. Depth of cut is also very simple and robust.
    After a couple of hours playing with it it seems to be a well thought out and solid tool. When running there is little or no vibration and it has worked smoothly in my test cuts. The built in bed extensions will also be very handy for the pieces I am planning on using it on.
      Posting comments is disabled.
    Latest Articles
    • A review of the Kreg Precision Trak & Stop Kit
      by twistsol
      Summary
      03-23-2022, 01:59 PM
    • Review of VIX-type Self Centering drill bits
      by LCHIEN
      The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
      08-29-2021, 11:18 PM
    • Grizzly Overarm Blade Guard review.
      by twistsol
      First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
      07-26-2021, 02:47 PM
    • Kreg KMA 3220 5mm Shelf Pin Jig
      by twistsol
      I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
      03-19-2021, 04:57 PM
    • Knife marking pencil Accutrax
      by LCHIEN
      Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
      01-14-2021, 01:25 AM
    • Saddle squares
      by LCHIEN
      Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
      01-13-2021, 12:20 AM
    The SawdustZone Statistics
    Topics: 61,755   Posts: 561,838   Members: 20,845   Active Members: 31
    Welcome to our newest member, WSposato.
    What's Going On
    There are currently 2317 users online. 0 members and 2317 guests.
