A Review of the Ryobi OSS500 Oscillating Spindle Sander
  • A Review of the Ryobi OSS500 Oscillating Spindle Sander
    By Ken Massingale Click image for larger version  Name:	oss500.jpg Views:	1 Size:	12.2 KB ID:	834649
    Input: 120 Volt AC, 3.5 AMPS
    Oscillations Per Minute: 58
    Revolutions Per Minute: 2,000 Shaft
    Arbor Size:
    1/2"
    Rubber Spindle Diameters: 3/4", 1", 1-1/2", 2", 3"
    Spindle Sizes (Sandpaper): 1/2", 3/4", 1", 1-1/2", 2", 3"
    Weight: 49 lbs
    Price: $99.95
    Includes: Spindle Sander (OSS500), Rubber Spindles, (3/4", 1", 1-1/2", 2", 3"), Spindle Sandpaper, (1/2", 3/4", 1", 1-1/2", 2", 3") in 50, 80 and 150 grits,
    6 throat plates, wrench, washers, Operator's Manual.
    I have used sanding spindles on my drill press quite a bit, but have never had access to an OSS. My expectations were high for this unit due to the up/down movement of the spindle, added to the rotation. And of course the Ryobi name brings high expectations. The first impression after picking the unit up at Home Depot and starting the unpacking process was favorable. The unit was well packed, everything was tight in it's little nook in the styrofoam packing with nothing damaged or missing. Pulling the unit from the box made me appreciate it's weight, 49 lbs., this is no toy!! The unit came with the 3/4" spindle and sandpaper installed. There is ample storage space for the other sizes of paper that are included, and this includes a complete extra set of all sizes. Every inch of room has been cleverly used on the OSS500 for storage. Other storage areas are for the six throat plates that are included and sanding sleeve/rubber spindles.
    O.K., let's get to the fun part, how well does it do what it was made to do!! The OSS500 was placed on a workbench plugged in and ready to go. The power switch was a little strange at first, you pull it out and up to start, but then it became apparent that this make quick turn off simple, just slap the front of the units base. Power on... Well not too loud, but definitely easy to tell it's running. I just happened to have a number of pieces of Cherry with heavy burn marks. We all know how easily Cherry burns, and how dang difficult it is to remove. Applying a piece of the Cherry I began to attempt to remove the burn marks, ready to spend quite a while in the process, based on performing the same task with sanding spindles on the drill press. I was very pleasantly surprised to see the burn marks disappearing almost immediately! In a matter of a couple of minutes, a total of 18 inches of marks on 3/4" stock were gone. But there was dust everywhere!! On the OSS500 top, the workbench and in the air. Time to test the dust collection feature, but based on other sanding tools so called dust collection I was prepared to be disappointed. The 2 1/4" hose from the Craftsman 6HP shop vac was slid into the DC port on the back of the OSS500 and fired up. (The dust was cleaned from all surfaces after the air borne material had settled.) Now I gathered several pieces of Walnut that I had just cut on the band saw. These were all 3/4" stock with practically no straight planes, just curves. They will be the feet and head pieces for several Quilt Racks I am building. Shop vac on, OSS500 on, the first piece was laid on the throat plate and applied to the spindle. Smoothing the band saw marks on the curved pieces was a pleasure. Quickly the edges became smooth and the little errors sawing, where the curves drastically changed direction were removed, resulting in some of the finest scrolling I have ever done! I found fairly soon that not much side pressure is required. fairly light pressure together with the rotation and oscillation of the sanding sleeves is all that is needed. As for the dust collection, there was no dust visible! None on the OSS500 table, workbench or in the air. And the internal ducting inside the OSS500 is such that the work pieces were held tight to the throat plate due to the suction. Tangible force was necessary to move the pieces against the spindle. The dust collection will vary based on the power of the shop vac or DC used.
    The OSS500 table top is narrow at the front (spindle location) and wider (15 3/4") at the back. This means that wider stock would be better worked standing at a side or the back of the unit. This places the power switch difficult to reach, but I don't consider an OSS the type of machine that requires rapid access to power down. The cast iron table top reduces vibration compared to units, such as the previous Ryobi OSS450, with MDF tops. About the only negative side I can find at this time is that the finest grit available presently is 150. Ryobi would be well advised to offer up to 220 grit sanding sleeves.
    In conclusion, I find the OSS500 great for the price. As I mentioned at the beginning, I haven't used other company's OSS's, but I have researched features and prices. The next lowest price I have found is Harbor Freight at $140, and they go up from there. Specs are fairly close between brands. I highly recommend this unit for woodworkers such as us. It is not a unit for professional shops, and is not intended for that purpose. Go get one and save yourself lots of time sanding, with better results.
    (Questions and comments about this review directed to Ken Massingale)
      Posting comments is disabled.
    Latest Articles
    • A review of the Kreg Precision Trak & Stop Kit
      by twistsol
      Summary
      03-23-2022, 01:59 PM
    • Review of VIX-type Self Centering drill bits
      by LCHIEN
      The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
      08-29-2021, 11:18 PM
    • Grizzly Overarm Blade Guard review.
      by twistsol
      First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
      07-26-2021, 02:47 PM
    • Kreg KMA 3220 5mm Shelf Pin Jig
      by twistsol
      I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
      03-19-2021, 04:57 PM
    • Knife marking pencil Accutrax
      by LCHIEN
      Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
      01-14-2021, 01:25 AM
    • Saddle squares
      by LCHIEN
      Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
      01-13-2021, 12:20 AM
    The SawdustZone Statistics
    Topics: 61,730   Posts: 561,621   Members: 20,829   Active Members: 30
    Welcome to our newest member, Mike Hinds.
    What's Going On
    There are currently 2096 users online. 2 members and 2094 guests.
