Potassium dichromate: chemically coloring wood
  • Potassium dichromate: chemically coloring wood
    The question comes up occasionally about using chemicals to change the color of wood. Usually the desired result is the color of aged wood--cherry and mahogany come immediately to mind as woods that develop rich, lustrous color when they are aged. Aging is free, but it's slow, and we're impatient woodworkers here in the 21st century.
    Dye stains can darken cherry or mahogany quickly, but the wood beneath the dye does continue to darken with age, and you can wind up with a darker piece than you really intended.
    So, is it possible to "hurry up" aging wood with chemicals? For some woods, yes. According to Understanding Wood Finishing, by Bob Flexner, Potassium dichromate reacts with tannic acid in wood. So woods with tannic content--oak, cherry, walnut, and mahogany--are good candidates for using dichromate coloring.
    Dichromate is available from a variety of sources, and the price can vary widely. I obtained a pound on ebay for under twenty dollars. As you'll see shortly, this is a lifetime supply. Dichromate is an orange powder. It dissolves in warm water to make a vivid orange solution.
    Dichromate is a hazardous chemical. Handle it with caution as you would with any wood finishing chemical. The powder is especially damaging to mucous membranes, so wear googles and a mask when you mix, and add the powder to the water instead of the other way around.
    David Marks has an article up suggesting 1 teaspoon of dichromate mixed with 1 cup of water as a starting point. For you metric users, that works out to about 9 grams in 250 mL of water.
    I mixed up a batch by these instructions, and used a foam brush to paint it onto samples of walnut, cherry, mahogany and oak. I'll let the pictures do the talking.
    The effect on mahogany is astonishing. Within a half hour the wood takes on a deep, rich coloration. All the luster of the grain and figure remains--the light plays off the grain the same as before the coloration. The look is not muddy or blotchy.
    Cherry can be a difficult wood to stain. but it takes the dichromate treatment well. I might mix a more dilute solution than the Marks formula above--cherry responds profoundly to the chemical.
    Walnut is suprising. the dichromate depens the color without obscuring the grain at all. It's more of what you buy walnut for.
    And on oak the effect is more subtle. It didn't knock me out at first but I really got to like it after a while..
    Since this is a water solution, you'll probably want to take the time to wet your piece with water before coloring, then dewhisker your work after it dries. The water will raise some grain, and you'll want to avoid having that telegraph through your finish. By doing that first, you avoid having to sand the colored wood.
    I'll put some more pics up in this tutorial once I get some time to take the test pieces through a final finish. I have read a lot of conflicting information about this technique (even Flexner discourages you from trying it!), so I had to try it myself. I highly recommend this method of aging for cherry, walnut, and most especially mahogany.
    I put a few coats of wipe-on poly on the samples, so show a more realistic contrast:
    Give this a try. It's well worth the effort to find a source.
      chopnhack commented
      I had a thought to discuss on the toxicity of the k+ dich. solution. Is it possible to attain the same level of oxidation using another oxidizer of tannin? Perhaps ammonia? Has anyone tried to brush on a strong solution of ammonia? Or does it have to be fumed "on" to work? I was just curious if anyone has done this to see a side by side comparison of the effects on the wood. This would of course bypass the whole toxicity issue of the heavy metal being left on the surface of the wood, chelated or not.
    • phi1l
      phi1l commented
      Here's a Link to Ammonia on another forum
      Also permanganate can be used for an oxidizer but it's not as strong as dichromate, so it would probably take longer to work. But it is not quite as much of a problem, environmentally.
      Apparently ozone can also be used. From http://www.rodbuildingforum.com/inde...aded&pid=56145 :
      "The smell in the air after a severe lightning storm is the smell of ozone. Ozone, being a strong oxidizer will also oxidize wood giving the wood a nice golden color that can only be duplicated with age. Since wood several hundred years old is not in great abundance, makers set out to time age their wood with the use of ozone. Any time spark is generated from electricity, some small amount of ozone is created. The hotter the spark, the more ozone produced. Lightning produces incredible amounts of ozone but it soon dissipates into the atmosphere. A great ozone generator can be made using a automotive coil, relay, and a few other available parts. The wood is placed in a sealed container with the actual spark gap. Yes, a spark plug will do nicely! There is also a heat rise inside the container however, the temperature is not likely to be problematic unless the container were too small in volume. In a few days, the work is done and the wood color will be consistent throughout."
      chopnhack commented
      thanks for the link, Phil. Some interesting lead there
    Posting comments is disabled.
Latest Articles
  • Pin Locked Joinery
    by Jim Frye
    This method is intended to replace nails, screws, and other metal fasteners in almost any type of wood joinery. The material is inexpensive and readily available in any grocery store. Simple hand tools are all that is needed to lock a wood joint and keep it from separating from use or age. The pins are bamboo kabob skewers and they typically run 1/8" to 5/32" in diameter making them a perfect size for wood joinery. Bamboo has straight, tough grain that is very resistant to shear forces....
    04-18-2025, 11:57 AM
  • How to set router bit and blade cut height accurately
    by LCHIEN
    How to set Bit and or blade height using various methods.
    By Loring Chien
    Oct 20, 2024
    Someone remarked how they had a hard time setting bit heights. Here is a brief tutorial on several ways and the best way I have found.
    The classic way is to use a ruler and measure the tip of the cutting bit, as shown below:
    This is some problems, hard to see, parallax, resolution. And that the tip of the bit is not flat but pointed. The cut will be to the depth...
    10-20-2024, 09:50 PM
  • How to drill perfectly placed hole into outside corner
    by LCHIEN
    Trying to drill into a outside 90 degree corner, 45° to each side, is tough, the drill bit keeps wanting to walk off.
    You can whack a small flat on the corner.
    But here is a way I did it perfectly. Using this corner drill jig
    Using the drilling jig, One hand is enough to hold the jig while drilling. The small vertical stick touching the top of the jig is my measurement stick. I use that to set the precise reproducible location of the hole relative to the top of the workpiece....
    04-26-2024, 09:41 PM
  • How to identify a Ryobi BT3000/BT3100/Craftsman 22811 or 21829 clone saw by sight
    by LCHIEN
    So you want to buy a BT3 clone. Been out of production for a while. Shopping on Craigs list or for sale ads is hard
    You have to keep an eye out and you have to be used to spotting the appearance giveaway features of the various models... Ryobi BT3000, BT3100, Craftsman 22811 and 21829
    There are certain things that clue you in and there are many ads that don't give model numbers and have crappy photos. Search for keywords RYOBI, Precision, System are often used in ad listings and
    12-19-2022, 11:53 PM
  • How to tell plunge router bits from non-plunge router bits.
    by LCHIEN
    Do you guys know your router bits?
    Do you know how to tell a plunge bit from a non-plunge bit?
    A non plunge bit has cutters around the periphery, but not the center. It can enter grooves from the side and cut moving sideways.
    A plunge bit has cutters that go all the way to the center of the bit face. It can cut moving vertically as well as sideways.
    Above see the bar across the center as well as the two edge cutters? Without this bar, when you drive the...
    12-22-2020, 02:09 AM
  • Festool Domino Settings for Evenly Spaced Mortises
    by twistsol
    I was in the shop this weekend and was trying to figure out the math for the settings on the Festool Domino to space the mortices evenly and centered across a cabinet front to back. After a bunch of trial and error with my math, I gave up and got close enough and cut the Domino slots for most of the cabinets before my shop time ran out. It was still bugging me, so I figured it out on the plane on the way to work.
    Very simply, we need to subtract the width of all mortises created from...
    01-28-2018, 10:46 PM
The SawdustZone Statistics
Topics: 61,766   Posts: 561,910   Members: 20,849   Active Members: 27
Welcome to our newest member, Smandeson11.
What's Going On
There are currently 3910 users online. 2 members and 3908 guests.
