Peachtree #447 2.5" Screw End Dust Collection Hose Adapter
I recently picked up a 50 foot segment of Peachtree Woodworking's 2.5" clear PVC dust collection hose in order to make some custom length hoses. (That is a separate review). In order to terminate those hoses, I grabbed some of Peachtree's screw end dust collection hose adapters. A simple little device that is nothing more than an injection molded part with the standard 2.25" O.D. friction fitting on one end, a flange / stop in the middle, and a 2.5" left hand screw thread on the other.
The molding of this item was amazingly smooth and clean. All injection molded plastic pieces should be this clean! There were no ridges, burrs, or odd pieces dangling from anywhere. Nicely done!
Installing these onto a bulk hose is simple, simply screw it into the hose, remembering that this is a COUNTER threaded item. Keep screwing them down until they stop, and then give the hose a gentle tug to make sure it took right and you are done!
The ends fit the females on my Shop Vac Sawdust Collection system flawlessly.
At the current price of $4.50 each, they are slightly overpriced, however, due to the fact that you do not need a hose clamp to retain the hose while using these, I would say in the long run they are worth what Peachtree is asking for them.
I gave documentation a 1 because this site doesn't have a zero rating. There was no documentation for this, nor should there be. If you can't figure out how to use these reading most likely isn't a strong point for you anyway...
I will be recommending these to my friends that are setting up their own workshops...Posting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- jig (1)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,292
Members: 20,635
Active Members: 67
Welcome to our newest member, dpkpankaj.
What's Going On
There are currently 10180 users online. 1 members and 10179 guests.
Most users ever online was 14,350 at 01:08 PM on Yesterday.
Footer Ad
dbhost commented
I am finding the size consistency among these ends is a little bit sloppy, which isn't a problem on anything other than my AP1301 planer, which has a port that is just a hair snug on a shop vac hose. Most of these connectors do not fit. I am having to use a Ridgid hose end on that one connection...
