I gave this a shot from a local retailer the other day
http://solutions.3m.com/wps/portal/3...293390692&rt=d.
The product itself seems very well made. The abrasive is tight to the backing and shows no sign of flaking off as others do. I used 320 and found it to cut very well. I would actually say the 320 cut better than the red Diablo 220g from the BORG. The actual backing is a rubber material that must be cut with scissors or a knife. It is extremely flexible and will conform to any shape, literally, with no creasing.
I did find that this product is so flexible that it tends to "roll" rather than move over the surface being sanded. I think the product is intended for sanding various profiles, and may be ok for that. I was sanding mostly flat surfaces an found that you could not "fold" the product, but instead really had to use a sanding block, or the paper would just roll. I haven't done a lot of sanding with it so I can't comment on how it holds up or loads up.
I think it's a great concept and I won't give up on it yet, but at this point, definitely would not look at this as a replacement for regular sandpaper.
3M Prograde Precision flexible sanding sheets
Created by:
sailor55330
- Published: 12-31-1969, 07:00 PM
- 4 comments
Categories
Article Tags
- BT3x00 (72)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- jig (1)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by
twistsol
Summary
Channel: Tool Reviews
by
LCHIEN
by
twistsol
by
twistsol
by
LCHIEN
by
LCHIEN
The SawdustZone Statistics
Topics: 61,768
Members: 20,856
Active Members: 24
Welcome to our newest member, Eztravia_US.
What's Going On
There are currently 4155 users online. 0 members and 4155 guests.
As for contours, I do like it, but I didn't see it in anything less than 320, so I think steel wool would still give a better final finish. Also, ultimately, I think steel wool conforms to small contours better because of the way the flex product rolls, but to be honest, I haven't really tried any intricate sanding with it.
YMMV.
