Handheld Metal Detector
  • Handheld Metal Detector
    I recently purchased this scanner to check lumber prior to planing and am very pleased with its performance and quality. I realize its from China, but hey what isn,t nowadays. Overall its very sensitive and easily scans a width of 8 inches. The price was great and although shipping take a few weeks I,m very impressed with the quality of this product and highly recommend it to others here. Heres the listing at E-Bay,.., http://cgi.ebay.com/Handheld-Metal-D...item2eadee66d9
    • tommyt654
      tommyt654 commented
      I realize now it may be hard to picture the actual size by the photo on e-bay so heres a photo of mine.It also works as a stud finder I just found out as well.
    • sweensdv
      sweensdv commented
      What is the world coming to.......someone has cloned a Harbor Freight tool. And it's even cheaper(ooops.....less expensive) than the HF one.
    • tommyt654
      tommyt654 commented
      Naw you don,t get the pack of smokes or the handy belt loop with the H.F. one, but seriously you can spend a lot more for an overpriced scanner like some folks here will probabaly do, but it performs the exact same function at a great price, and this things probably weighs 2 1/2 lbs give or take so its built fairly well,also has a vibration sensor and adjustments for sensetivity. We all know sween will like that
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 02:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-30-2021, 12:18 AM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 03:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 05:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 02:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 01:20 AM
The SawdustZone Statistics
Topics: 61,768   Posts: 561,921   Members: 20,856   Active Members: 23
Welcome to our newest member, Eztravia_US.
What's Going On
There are currently 5457 users online. 0 members and 5457 guests.
