MLCS Digital Angle Rule
  • MLCS Digital Angle Rule
    I was in the market for a Wixey Digital Angle Gauge, but while shopping at MLCS online, I found a "new item" - their Digital Angle Rule. Since the rule appeared to have more functionality than a Wixey gauge alone, and retails for a few bucks less than a Wixey gauge ($34.99), I picked one up.
    It functions as a protractor. Comes with one CR2032 Li Battery not installed (new), has a readout that displays in tenths/degree, and can be zeroed out from any position of the two rules (relative to each other.) The most useful positions to zero for me are 0 deg (for normal use) and 180 deg - if you zero out at 180 deg, you can set the rule to an angle greater than 180, (such as 225 deg), and it will read 45 deg - useful for checking blade angle on my saw.
    The rules are nice quality, and the plastic display portion seems of adequate durability - the instructions do say to basically treat it carefully, since its a "precision instrument". The specs say accuracy is 0.3 deg, but I find mine to be closer - within 0.1 deg.
    There's no "brand name" on this item, so it wouldn't surprise me if this eventually shows up at Harbor Freight for fewer $, but I still find the MLCS price reasonable for a fairly versatile tool. And I think I'll be able to forgo getting the Wixey.
      Posting comments is disabled.
    Latest Articles
    • A review of the Kreg Precision Trak & Stop Kit
      by twistsol
      Summary
      03-23-2022, 02:59 PM
    • Review of VIX-type Self Centering drill bits
      by LCHIEN
      The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
      08-30-2021, 12:18 AM
    • Grizzly Overarm Blade Guard review.
      by twistsol
      First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
      07-26-2021, 03:47 PM
    • Kreg KMA 3220 5mm Shelf Pin Jig
      by twistsol
      I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
      03-19-2021, 05:57 PM
    • Knife marking pencil Accutrax
      by LCHIEN
      Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
      01-14-2021, 02:25 AM
    • Saddle squares
      by LCHIEN
      Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
      01-13-2021, 01:20 AM
    The SawdustZone Statistics
    Topics: 61,768   Posts: 561,919   Members: 20,854   Active Members: 22
    Welcome to our newest member, M3lR52.
    What's Going On
    There are currently 4283 users online. 0 members and 4283 guests.
