Incra Universal Precision Positioning Jig
  • Incra Universal Precision Positioning Jig
    I picked this jig up when Rockler had a sale on it. If you bought the jig, you got the fence and right angle jigs free. Cost was $60 total. Normally about $120. (the $120 is the reason for the 4 for value. $60 is worth it, $120 is a bit high.)
    I've watched the video probably three times now. My hope was that I could go into the shop and have an easy time setting it up. Essentially, I did have an easy time.
    I was going to make 1/2 blind dovetails for a drawer. The drawer width was critical to fit in the cabinet, but the drawer length didn't matter much.
    I followed the instructions, made the test cuts. Took about 6 tests to get the bit height correct. Now that I have it, I'll cut a piece to keep with it.
    I made one mistake, when you make your centering cut, you are then supposed to line up the "pattern strip" with the center. I forgot to do this so my dovetails weren't centered. This will keep the drawer front and back from lining up correctly with the drawer sides.
    I went ahead and cut off the dovetails, since it was in the sides anyway, and recut them after centering the "pattern strip".
    After that it was pretty much smooth sailing.
    If you were making multiple drawers the same size, this thing would be great! Mine are a total of 4 drawers and all different depths, so I would need to recenter the jig for each drawer. Not a really big deal though, just an extra step.
    So far I really like the jig and think it will be very useful in my shop. I plan to build a really large wall mounted router station in the next few months, and I have incorporated the use of this jig in the design.
    • jhart
      jhart commented
      Thanks for the review. Sounds like an excellent value at $60. May have to take a look at it next time I'm in Rockler's
    Posting comments is disabled.
Latest Articles
  • A review of the Kreg Precision Trak & Stop Kit
    by twistsol
    Summary
    03-23-2022, 02:59 PM
  • Review of VIX-type Self Centering drill bits
    by LCHIEN
    The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
    08-30-2021, 12:18 AM
  • Grizzly Overarm Blade Guard review.
    by twistsol
    First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
    07-26-2021, 03:47 PM
  • Kreg KMA 3220 5mm Shelf Pin Jig
    by twistsol
    I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
    03-19-2021, 05:57 PM
  • Knife marking pencil Accutrax
    by LCHIEN
    Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
    01-14-2021, 02:25 AM
  • Saddle squares
    by LCHIEN
    Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
    01-13-2021, 01:20 AM
The SawdustZone Statistics
Topics: 61,768   Posts: 561,921   Members: 20,856   Active Members: 23
Welcome to our newest member, Eztravia_US.
What's Going On
There are currently 4496 users online. 0 members and 4496 guests.
