Jasper Circle Guide for routers
  • Jasper Circle Guide for routers
    I asked in the Tool Talk forum and at an Audio DIY forum about the best way to route nice circles for building speakers.
    Got some great replies and saw some honest ingenuity and home made jigs to accomplish this task.
    A few guys mentioned this Jasper Circle Guide and I purchased it at Parts Express. Set it up in no time and was cutting perfect circles up to 18" with no fuss and no fancy adjustments between size switches.
    Place your material on a backer, drill a 1/8" hole in the center through and into the backer, select the circle size on the index in 1/16" increments and insert the pin in the guide hole coresponding to the circle size you want to cut. Place router and guide on material and the pin through the 1/8" hole and into the backer.
    Router requires a 1/4" UP-CUT spiral bit, (Other straight bits will probably work as well).
    I cut circles for 4" and 14 1/16" in less then 2 minutes in MDF and was very happy the dust stayed down and under the plate for easy clean up.
    This is a nice tool and makes my work alot simpler then how I was doing it before.
    Gary
      Posting comments is disabled.
    Latest Articles
    • A review of the Kreg Precision Trak & Stop Kit
      by twistsol
      Summary
      03-23-2022, 02:59 PM
    • Review of VIX-type Self Centering drill bits
      by LCHIEN
      The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
      08-30-2021, 12:18 AM
    • Grizzly Overarm Blade Guard review.
      by twistsol
      First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
      07-26-2021, 03:47 PM
    • Kreg KMA 3220 5mm Shelf Pin Jig
      by twistsol
      I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
      03-19-2021, 05:57 PM
    • Knife marking pencil Accutrax
      by LCHIEN
      Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
      01-14-2021, 02:25 AM
    • Saddle squares
      by LCHIEN
      Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
      01-13-2021, 01:20 AM
    The SawdustZone Statistics
    Topics: 61,768   Posts: 561,921   Members: 20,856   Active Members: 24
    Welcome to our newest member, Eztravia_US.
    What's Going On
    There are currently 5148 users online. 0 members and 5148 guests.
