GMC $39.95 Router Kit
  • GMC $39.95 Router Kit
    Wasn't sure where to put this but wanted to be sure it was seen. I purchased this at the bottom price of $39.95. There was at least one post on the forum that cited a problem with the bit rising and falling when the router was turned on. I wanted to be sure that mine did not have this feature. I guess I am satisfied with the purchase, but only because it was inexpensive. Had I paid full price I would certainly return this tool. Setting bit height is not very smooth and the scale to do this rotates too easily and can cause errors. Advice: measure it and don't bother with the depth ring.
    The overall feel of the tool is cheap, while the bases are magnesium, they have the feel of plastic. Some of the dust collection tubes were cracked when I opened the case. Not worth sending back for this issue.
    The slow start is very slow and it seems to take a long time for the router to reach top rpm. When it does it is quite a bit louder than my Hitachi. I believe it is bearing noise so I am not sure this router will last that long.
    I had a tough time mounting this to the BT3100 router table as the base of the router is quite large. Finally managed it, but the mounting plate now looks like swiss cheese.
    Edge routed a piece of pine and it did OK, no slowing or burning. I will try some hardwood next.
    For $40 or $50 its just OK, more than that and it falls short on the value for this type of tool. I will leave it on the BT3100 as a dedicated edge router and do the rest on my router table with the Hitachi. If it fails I will not buy another, even at the $40 mark.
    I also purchased the handheld planer which works well and seems to be a better tool than I expected. Paid $19.95, free shipping.
      Posting comments is disabled.
    Latest Articles
    • A review of the Kreg Precision Trak & Stop Kit
      by twistsol
      Summary
      03-23-2022, 02:59 PM
    • Review of VIX-type Self Centering drill bits
      by LCHIEN
      The problem comes about with small bits like 1/16 and 5/64 and 3/32"...
      08-30-2021, 12:18 AM
    • Grizzly Overarm Blade Guard review.
      by twistsol
      First impressions were that this is an extremely solid and well built unit. It's made mostly of steel and connects to a 4" DC hose. There were a number of issues getting it set up and installed, and a...
      07-26-2021, 03:47 PM
    • Kreg KMA 3220 5mm Shelf Pin Jig
      by twistsol
      I decided to look for the rock bottom cheapest 32mm drilling system available that would let let me create real 5mm holes spaced 32mm apart, that was easy to use, and didn’t require a bunch of setup time. I’m really surprised at how much I like this little Keg jig especially when you consider the price of $34.99, and it has everything included. There were a couple of jigs cheaper but you needed to buy a self-centering 5mm bit to go along with them so they would...
      03-19-2021, 05:57 PM
    • Knife marking pencil Accutrax
      by LCHIEN
      Here's mine. I have not broken it, it seems to be quite sturdy. The sharp edge lasts a long time. I'm still on the...
      01-14-2021, 02:25 AM
    • Saddle squares
      by LCHIEN
      Works really well when the board has a rounded edge or some wane where the edge is not really sharp and square but the two adjacent faces are square to...
      01-13-2021, 01:20 AM
    The SawdustZone Statistics
    Topics: 61,770   Posts: 561,925   Members: 20,860   Active Members: 26
    Welcome to our newest member, handcraftedmodelshipsca.
    What's Going On
    There are currently 4653 users online. 0 members and 4653 guests.
