BT3000 Jig Saw Mount
  • BT3000 Jig Saw Mount
    BT3000 Jig Saw Mount Designed by Jim Frye
    This setup uses an old Jig Saw and a 3/4” thick plywood router mounting plate. The mounting plate is cut and relieved to hold the base of the jig saw against the underside of the BT3K accessory table. Since this was a spare jigsaw, it is permanently mounted in the plate with adhesive. Different saws will require different cutting and relieving and could conceivably be mounted with screws and nuts to facilitate removal from the plate. Thus, there are no drawings with this file, just some pictures to show the finished product. I used a curved sink tail pipe screwed to the mounting plate to provide a shop vac hose connection point. I used masking tape to enclose the space between the saw and the pipe to further enhance the dust pickup. Note the steel washers epoxied to the mounting plate to provide crush protection when the jig is bolted to the BT3K table.
    Original PDF Document:
    jigsawins.pdf
    BT3000 Jig Saw Mount Designed by Jim Frye 01
    BT3000 Jig Saw Mount Designed by Jim Frye 02
    BT3000 Jig Saw Mount Designed by Jim Frye 03
      Posting comments is disabled.
    Latest Articles
      by LCHIEN
      I'm pretty...
      11-30-2025, 02:24 AM
      by LCHIEN
      11-30-2023, 04:00 PM
      12-06-2023, 10:19 PM
      by LCHIEN
      07-09-2023, 01:37 PM
      by LCHIEN
      05-24-2023, 08:55 PM
    • Another Thin Strip Jig
      by twistsol
      In the starting position,...
      04-16-2023, 09:42 AM
      by LCHIEN
      BT3000 tall rip fence
      09-12-2021, 07:58 PM
      10-20-2021, 02:27 AM
    The SawdustZone Statistics
    Topics: 61,761   Posts: 561,895   Members: 20,847   Active Members: 29
    Welcome to our newest member, RobertBrown9.
    What's Going On
    There are currently 3986 users online. 3 members and 3983 guests.
