Craftsman BAS350
Recently, I became the owner of a Craftsman BAS-350 14" band saw. I thought you would be interested in hearing about it, even tho I haven't had a chance to use it much yet.
I have owned 2 bandsaws in the past. One was a B&D 10" 3-wheeled job, which I got rid of and bought a Delta 9" model. Turned out it wasn't an upgrade, and I've been watching for a replacement. The wife finally gave me the go-ahead to buy another. Having read good reviews of Sears 10" model here and other web sites, and since it was on sale, I went to check it out. While I was there I also saw the 14" saw and it seemed more substantial.. I am also a hobbyist and enthusiast and not a professional.
My first observation is that shopping at Sears is makes you feel like you've jumped into a pool of marketing morons Or perhaps they are geniuses, using tricks I can't comprehent. Whatever, they seemed silly to me. The 14" saw was 449, available on-line for 359. Or you could buy it on the spot for 399. The salesman couldn't do any price-matching, but he showed me the on-line kiost where I could order it for 359. Either way, I was going the have to wait 10 minutes to get it.
While I was punching buttons, the salesman let me know that he didn't get any commission on sales on-line, but because he was "helping" me place an order at a kiosk, he would get a double commission.
Conclusion... Sears really wants to shut down all their store fronts and become like Amazon or Montgomery Wards.
Anycase, 10 minutes later they roll out the band saw - Sears views theit saws as "band saws" and most every other model as "bandsaws" - and I note two things right away. The box is a mess, and it won't fit in the trunk of my Hyundai. The box weighs 160 lbs, so it's lucky for me that it won't. I return the next day with a helper and his pickup truck, and get the thing into my basement.
Getting the box home, I discovered that the styrofoam inside was also beat up. However, the saw didn't show any scratched or marks, so it seems to have been protected enough.
Setup took several hours over the next few days. During that time I learned that the wheels seemed balanced - as best I could tell by spinning them and marking the bottom. The cast iron table seems big to me, but I don't have much to compare with. A nickel - standing on end - will stand and vibrate for a while before it falls over; a quarter and dime would not.
The legs are too large to fit in a reasonably priced mobile base that I've found to date; I'm looking for ideas on building my own.
The saw comes with neither a miter bar nor a resaw fence; the lack of them does not bother me. The miter bar from my 4512, as well as my Kreg model, fits fine. And I'm found several plans for resaw fences when I want to try building one.
The saw goes through a piece of oak nicely, both cross cutting and resawing. I've only tried the quarter inch blade that came with the saw.
The blades are an unusal size; 99 3/4s. However, some google searches have found several sources for them besides Sears. The saw claims 8 inches of resaw capability; I haven't tested that yet.
It is a little irritating that I have to remove the screw from the table top to open the bottom drawer, but not a deal breaker. I can't speak to the accuracy of the tension guage; it works and the saw cuts when it is set.
Sears marked the saw down another 30 bucks a few days after I got it. I got online and called India (whereever) for help and they told me they corrected my bill.
The saw vanished from the Sears web page for a week, leading me to suspect that it was on clearance. However, I notice today that it is listed again.
I'm very happy with the new bandsaw (or band saw); does want I need at I price I'm happy with.
Thanks very much for reading. If you have any more question, please let me knowPosting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- sanding block (1)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,292
Members: 20,635
Active Members: 67
Welcome to our newest member, dpkpankaj.
What's Going On
There are currently 14055 users online. 3 members and 14052 guests.
Most users ever online was 14,350 at 01:08 PM on Yesterday.
Footer Ad
Sears BS350:
Finnish HBS-350N
http://www.sorvisoppi.com/tuotteet.html?id=14/ (have to translate finnish to English)
SPECIFICATIONS
HBS 350 N Motor power 1.0 kW Rear Wheel diameter 355 mm Dust extraction Connections 100 mm Table tiltable 0 - 45 ° desk height 1010 mm Table size 400 x 548 mm Blade speed 440/880 m / min ..
mpc
p.s.: Sears pricing makes as much sense as Harbor Freight pricing a few years ago - store prices differed from the Internet prices; stores would honor internet prices but not the other way around, and stuff was frequently on sale at one of 3 or 4 different common sale prices. The sales clerk training at my local Sears seems to be nothing more than "credit card stripe goes this way when you swipe it through the reader" as well.
