Kreg Precision Band Saw Fence
Yesterday(8-8-09) I pulled the trigger on Kreg's band saw fence assembly. I expected Kreg's usuall attention to quality and detail and was not disappointed. The packaging was complete(no missing parts!) and the assembly and installation instructions were clear and well written. The only glitch I ran into was the front guide rail mounting holes were not drilled to fit my model bandsaw. I have an old King-Seely Craftsman unit which runs flawlessly. Following the instrutions in the manual, I was able to lay out a new mounting hole and drill it out on my bench drill press. Total install time, including reading the instruction manual was about 45 mins or a little less. I would recommend this tool to anyone who is looking for a quality fence upgrade to their bandsaw.-
#1Duane867 commented08-30-2009, 02:48 AMEditing a commentI just saw this unit set up on a Powermatic band saw while at Rocklers retail store this Saturday actually. very nice looking set up. Simple to use, straight forward in setting up, and seems to be plenty sturdy.
Posting comments is disabled. -
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- sanding block (1)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,292
Members: 20,635
Active Members: 67
Welcome to our newest member, dpkpankaj.
What's Going On
There are currently 10690 users online. 3 members and 10687 guests.
Most users ever online was 14,350 at 01:08 PM on Yesterday.
Footer Ad
