Pittsburg 34387-2VGA 6" wood handle bar clamp.
I gave the rating a 1 on Documentation, because... Well do you REALLY need documentation on how to operate a bar clamp?
I picked up a bunch of these based on price, and a friends recommendation. This review also mimics how I feel about the 12", and 24" sizes which I own, and use as well...
The 6" bar clamp sold by Harbor Freight under the Pittsburg name comes with wooden tightening handles, quick adjust lever that you simply depress, and slide to as close as possible to your desired location, and twist the wooden handle until it is tight enough.
WIth good strong hands, this clamp is capable of leaving some NASTY clamps in handrwood if you over tighten. Using scrap culls is a good practice anyway.
I have found in the time that I have had mine, they are every bit as good of a clamp, as my Jorgensen Pony clamps, and have some features that my Joregensens lacked (clamp pads were included with Pittsburg, not with Jorgensen). And for the price, I have been able to afford a dozen each of the 6", 12", and 24", as soon as they get more 36" models in stock I will pick them up.
The longer sizes seem to bow under pressure, but no more so than the big name brand clamps. It seems more to be a behavior of the design than anything else....
For a great clamp at a bargain basement price, I would gladly recommend that anyone pick up as many of these clamps as they need, and a few more because you can never have too many clamps!Posting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- sanding block (1)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,292
Members: 20,635
Active Members: 67
Welcome to our newest member, cjn.
What's Going On
There are currently 14775 users online. 1 members and 14774 guests.
Most users ever online was 15,771 at 02:28 PM on Today.
Footer Ad
sale rubbery handle ones too. Can't seem to add the numerical review, but would give
them a 4, with value one of the best features.
