Relay booster box
  • Relay booster box
    Over the years i've posted a number of things. one popular one was the relay booster box. this allowed a 1-15 A trigger to operate a high current and or high voltage device like the bigger dust collectors 20 or more amp and 120 or 240 volts.. The trigger was from another high current tool like a table saw. this prevented the DC and the TS from working off the same breaker. or to use a low current remote - most don't like big motor loads - to control the DC, or to use different voltages
    The instructions are reposted thanks to Relative who stored them in his server prior to this forum allowing PDF files.
    I am putting them back in the forum attachments here
    the instructions cover three versions
    • Tool switch controlling relay with separate 120 V power
    • remote control controlling 120 V relay
    • remote switch controlling 220 V relay
      Posting comments is disabled.
    Latest Articles
    • Replacement BT3x00 Miter Fence Holder shop made Rod Kirby original design
      by LCHIEN
      After he retired his BT3000, Rod Kirby sent me his original shop made miter fence holder that was famously in all his posts. Typical Rod Kirby craftsmanship. Not that hard to make.
      Really takes a top plate, a block and a compound T-slot...
      11-30-2025, 03:39 AM
      by LCHIEN
      I'm pretty...
      11-30-2025, 03:24 AM
    • Lead Shot/Epoxy Infill For Tool Parts
      by Jim Frye
      I've been using lead shot and epoxy for over two decades to add strength and mass to hollow plastic and die cast metal parts of tools. I use #9 lead shot (steel shot could be substituted) to add mass to lightly molded parts. The epoxy doesn't need to be high strength as it's being used to encapsulate the shot in the cavity, so pourable resin works fine. The epoxy binds and seals the shot into the cavity(s) of the part. The fineness of the shot allows it to fit into odd or irregular shaped cavities...
      04-27-2025, 08:03 PM
    • Pin Locked Joinery
      by Jim Frye
      This method is intended to replace nails, screws, and other metal fasteners in almost any type of wood joinery. The material is inexpensive and readily available in any grocery store. Simple hand tools are all that is needed to lock a wood joint and keep it from separating from use or age. The pins are bamboo kabob skewers and they typically run 1/8" to 5/32" in diameter making them a perfect size for wood joinery. Bamboo has straight, tough grain that is very resistant to shear forces....
      04-18-2025, 12:57 PM
    • 14x36 Benchtop Lathe Build
      by Jim Frye
      This lathe was assembled using parts from a Ryobi ML618 mini lathe. I purchased it as a factory refurbished tool at a truckload sale in a mall parking lot for $215 in 2000, but it did come with a factory warranty. It had some serious design limitations that I thought could use improving on. It started out as a 6" swing, 18" between centers machine and ended up a 14" swing, 36" between centers lathe. I have spent less than $300 assembling this lathe. This is most likely...
      04-10-2025, 02:53 PM
    • How to set router bit and blade cut height accurately
      by LCHIEN
      How to set Bit and or blade height using various methods.
      By Loring Chien
      Oct 20, 2024
      Someone remarked how they had a hard time setting bit heights. Here is a brief tutorial on several ways and the best way I have found.
      The classic way is to use a ruler and measure the tip of the cutting bit, as shown below:
      This is some problems, hard to see, parallax, resolution. And that the tip of the bit is not flat but pointed. The cut will be to the depth...
      10-20-2024, 10:50 PM
    The SawdustZone Statistics
    Topics: 61,772   Posts: 561,930   Members: 20,861   Active Members: 27
    Welcome to our newest member, cian.
    What's Going On
    There are currently 2616 users online. 2 members and 2614 guests.
