HF 12" quick clamp
The Harbor Freight 12" quick clamp/spreader looks like a great buy when on sale with coupon for $1.99, however, the main drawback with these units are that they fail when too much pressure is applied.
The unit appears to be well made with a steel ratchet bar and a hard dense pvc for the handle. It has non marring pads for the jaws and works very smoothly. My initial impressions at the store were quite good and I picked up 6 of them thinking what a steal. It was only in use did I realize the achilles tendon was the pivot point contained in the housing of the handle. Inside the handle on either side is a round protrusion that the trigger handle fits over. If too much pressure is applied the round protrusion shears off of one side and the unit is broken.
The easy fix that I applied was to disassemble the unit by removing 5 phillips head screws, locate the failed pivot point, drill it out, reassemble with trigger handle centered on the hole and drill through to the other side of the handle. Install a machine screw, lock washer and nut and your good to go
The unit will work again, but there was no increase in clamping power, nor did I expect one when I saw the inner working of the clamp. The release button pushes against a steel plate to relieve the tension, but the squeeze handle (trigger) pushes on a plastic piece! So without removing and replacing this too, the same clamping force can be applied, otherwise you end up just bending that plastic follower.
If you find this useful rate the thread and add to my reputation, thanks
Forgot to complete this review with photos of fix:
Drill out using 3/16" bit, use 3/16" fine thread machine screws with flat head and no undercut (flat under screw head) 1" long, lock washer and nut.
Clamps with new life!
Posting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- sanding block (1)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,292
Members: 20,635
Active Members: 67
Welcome to our newest member, dpkpankaj.
What's Going On
There are currently 14616 users online. 2 members and 14614 guests.
Most users ever online was 14,822 at 01:07 PM on Today.
Footer Ad
I've found the same thing w/these clamps. Inadequate for most woodworking since they have very low pressure, slip and the jaws splay out, but my brother finds them useful for metalworking, when needing to clamp pieces for welding.
