Ryobi P150 Fuel Gauge
At first glance, the Ryobi P150 Fuel Gauge might seem like a frivolous device, but after five months of use, I find it a very useful part of my cordless tool set. How many times have you grabbed a cordless tool, hiked upstairs or outside to use it, only to have the supposedly charged pack give up after a couple of minutes of use? I have had that experience many times. The $10 P150 takes the guess work out of picking a battery to use. I have six One+ packs and even though I take pains to ID which ones have had some usage since they were charged, I sometimes would grab one that wasn't up to snuff for the job at hand. Then it was back to the basement shop to fetch another pack, or two, to finish the job. With the P150, this is a non-issue. To use the fuel gauge, all you do is plug it onto the post of the battery pack in question. In a couple of seconds you know the status of the pack in four LED lights. The first thing the gauge does is run a test of the pack and counts down the test by lighting the red, yellow, and two green LEDs in that sequence. Then it turns the lights out and progressively lights the LEDs until it determines the amount of charge left in the pack. Here is the explanation from the P150 manual:
RED LED only: Battery pack needs recharging
YELLOW LED: Partial charge
One GREEN LED: High partial charge
Two GREEN LEDs: Fully charged
NO LEDs: Dead battery pack (completely discharged)
This simple little device has eliminated the trips back to the shop for more batteries. This will also let you check how well a pack is holding a charge on the shelf, so you know before you are stuck without a spare battery.
Oh yeah, it works with the LiOn packs also, even though they have a built in check button on them. The P150 just gives you a fourth level.-
#2jhart commented08-24-2009, 06:26 AMEditing a commentI wasn't aware of the item you reviewed, but with having 5 batteries, it's a great idea, as mine also are in the basement. Thanks for the info, Jim
#3LCHIEN commented08-24-2009, 07:05 AMEditing a commentso how much does HD get for those?
#4Jim Frye commented08-24-2009, 08:04 AMEditing a commentCheap at half the price...Originally posted by LCHIEN
Posting comments is disabled. -
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- jig (1)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by twistsol
Summary
Channel: Tool Reviews
03-23-2022, 02:59 PM -
by LCHIENI have always had trouble mounting small hardware on small wood boxes, with the hasps and hinges always looking slightly off perfectly square - particularly a problem with flat head screws and countersunk hardware which aligns the hardware to the hole location and centers on the hole.
08-30-2021, 12:18 AM -
by twistsolSince my new shop is in the basement, dust collection is a bit more important than when I had my own building and could do as I pleased in the shop. With that in mind, I upgraded the dust collection on my table saw. I purchased the Grizzly Overarm Blade Guard to use with the saw.
07-26-2021, 03:47 PM -
by twistsol
03-19-2021, 05:57 PM -
by LCHIENHere's a tool I found useful for marking. Accutrax pencil blade marking knife.
01-14-2021, 03:25 AM -
by LCHIENHey, I'm sharing one of my favorite tools. A Veritas Saddle Square. Actually I have two in different sizes. This is the large size for marking 2x4 and 4x4 (shown on 4x4 here). One of those tools that makes woodworking a pleasure.
01-13-2021, 02:20 AM -
The SawdustZone Statistics
Topics: 61,292
Members: 20,635
Active Members: 67
Welcome to our newest member, dpkpankaj.
What's Going On
There are currently 10914 users online. 0 members and 10914 guests.
Most users ever online was 14,350 at 01:08 PM on Yesterday.
Footer Ad
