Personal “2x6 Challenge”
  • Filter
  • Personal “2x6 Challenge”
    There is a lumber rack in the garage that has been there since my original “woodworking days”. Mostly forgotten. But I just discovered several unused 2x6’s… most likely bought in anticipation of a BT3Central 2x6 Challenge.
    I’ve got several projects on the radar that I could utilize them for, so I figure I might post the “results” here, as well as challenge my fellow SawdustZone comrades to do the same. So… over the next few months, I hereby challenge YOU to post pics, descriptions, details about how you utilized the humble 2x6 to complete a project.
    GO!
    Sam Conder
    BT3Central's First Member
  • #2
    Oh me, now I need to use what is left of my brain! I certainly have enough tools! I need the challenge!
    • #3
      OK, I used more than just 2x6s. All of these were built from 2x construction scraps from the homes built around us. Joinery is biscuits and glue. Edges are 3/4" round over. Casters are from HD, locking in the front and fixed in the rear. Doors are scrap 3/4" plywood. Hinges are replacements from when I replaced old doors with six panel oak doors. Latches are cheap purchased. And that is my original BT3000 from 1993 that was used to cut all of the wood for these.
      Click image for larger version  Name:	2D1A81A6-79B0-49DB-A196-C9C3D8BC7E42.jpg Views:	0 Size:	179.4 KB ID:	853866
      Jim Frye
      The Nut in the Cellar.
      ”Sawdust Is Man Glitter”
      • #4
        What were rules of this challenge?
        • #5
          The rules from the 2011 2x6 Challenge, which I believe were the same as the original are as follows"
          So far the rules are simple:
          • Materials choice is limited to one stick nominal 2"x6"x8' std & btr. grade construction lumber as is commonly available at a home center or box store in the members zip code. (like we will be able to check this).
          • You may use other wood, metal, fabric, hardware, etc. as long as the focus remain on what you can make from the 2x6. The other material is for accent or hardware use only. The project shall not depend on an accent. Limit to <10% of project.
          • Registration deadline is March 31, 2011.
          • All projects must be submitted no later than 12:00 PM EST April 30, 2011.
          • Judging will be by popular vote by members via the forum poll function.
          • Prizes will be awarded based on member polls, meaning at this time we do not have a breakdown. Please add you input in the comming month to the prize poll.
          By the way, if anyone has squirreled away the pictures of the entrants from the 2005 2x6 challenge, I would love to restore them to the site. There was some pretty impressive stuff done with a single 2x6.
            LCHIEN commented
            have you checked the internet Wayback machine archives?
        • #6
          For inspiration, here's a video of a cabinet made from a 2x6:
          • Sam Conder
            Sam Conder commented
            Very cool, Nick!
          • nicer20
            nicer20 commented
            Wow !! Amazing craftmanship ...
        • #7
          I’ll give it a shot. I have a friend in Ireland and we occasionally get bored or otherwise tired of the shop and challenge ourselves to grad one piece of scrap wood and make something.
          when is this going to happen?
          • #8
            My entry from the first 2x6 contest 2005
              twistsol commented
              One down a bunch to go. Thanks Mark.
            • nicer20
              nicer20 commented
          • #9
            Here were the 2005 entries by name and titel, but no pictures were found
              twistsol commented
              If I recall correctly, you had to be a member to see images back in the olden days.
          • #10
            Oh wow sounds interesting - what are the new rules? Most importantly, what is the deadline?
              leehljp commented
              Same as Old rules:
              "Materials choice is limited to one stick nominal 2"x6"x8' std & btr. grade construction lumber as is commonly available at a home center or box store in the members zip code. (like we will be able to check this).
              You may use other wood, metal, fabric, hardware, etc. as long as the focus remain on what you can make from the 2x6. The other material is for accent or hardware use only. The project shall not depend on an accent. Limit to <10% of project."
              Date: not yet mentioned. Stay tuned.
          • #11
            it seems to be a different contest as in not a contest at all. More of a challenge to members to do something out of the ordinary. Design and complete a project using just a 2x6x8 construction grade stick of lumber. The important part is to post your journey. Your reward is satisfaction and kudos from other members.
            For example, I recently added to my shop a pin gauge set. The plastic box they came in was damaged in transit as would be expected based on item reviews. I am thinking about making a case for them anyway. Might as well search for the perfect stick of 2x6 to be resawed, glued into panels and joined to make a hinged box to case my precision gauges.
            nicer20 thanks for the complement. If only you could see the other entries. There were a number that were far more complex than mine. kwgeorge I believe won overall with a spider chair? Anyway his presence on this forum mostly about turning was huge. Jim in Texas was also very talented and posted lots back in the day. He "discovered" segmented turning and became addicted to lathe work. Stan made and submitted a rifle cleaning vise that puts the commercial offerings to shame. Sadly I don't recall all of the great entries. The beautiful part was so many just removed the chips and dust to reveal what the wood was meant to be.
              LCHIEN commented
              Post#9 in this thread lists the entries and winners. unfortunately the pictures were lost in a site upgrade.
          • #12
            I’ve been thinking and looking at some previous projects that fit the bill for this event. This step stool is one I made from some scrap 2x8 but I bet I could improve it some and use the 2x6. Click image for larger version
            • Black walnut
              Black walnut
              commented
              One of my very first projects after buying my BT3K was to build a step stool. Full width legs with angled rabbets fitting tightly into angled dadoes in the top with small midway stretchers secured with two wood screws at each end. and wood glue. I believe that was 1999 and we use it daily in our bathroom to get in and out of the tub. Amazes me to this day that it has held up. Tight joints with a good glue bond and likely small enough that it doesn't flex.
            • Dedpedal
              Dedpedal commented
              Awesome. This one was an exercise in boredom combined with a need to be able to reach the sleds that hang on the wall. They are about 6” out of reach and bringing a step ladder in every time I needed one was getting old.
              I only used glue and oak dowels for this one.
          • #13
            I had to dig deep to find photos of my entry. I was "Knuckles" back then.
            Click image for larger version  Name:	topview.jpg Views:	0 Size:	35.3 KB ID:	854001
            It's still in use.
            Brian
            • #14
              I should probably grab a 2x6 or 2x8 actually, I need a step for the truck camper...
              • #15
                I'm in. I've got a project in the que that SWMBO wants for the RV. Should come out of single 2x6 easily after some resawing.
