In a “Fundamentals of Woodworking” class I attended taught by Marc Adams at the Indianapolis woodworking show, he stated that he uses ordinary white glue instead of yellow glue for the majority of his joinery. I decided to do a little research on the two types of adhesives and was surprised by what I found.
White glues like Elmer's Glue-All are polyvinyl acetate (PVA) based adhesives. Yellow glues like Pro-Bond and Titebond are aliphatic resin glues, which are merely PVA adhesives with additives to resist moisture. According to the Titebond website a PVA glue is defined as “any glue consisting chiefly of polyvinyl acetate polymer. This category includes both traditional white glues and yellow aliphatic resin glues.”
So why the additives? They must help, right? Well, yes and no. The first yellow glue was introduced by the makers of Elmer's Glue-All, and was called Elmer's Carpenter's Wood Glue. The name implies the need for the additives. Carpenters most often work with lumber with a moisture content around 20 percent (or higher), not the 6 to 9 percent moisture of the lumber used in woodworking. The “glue scientists” at Elmer's found that adding some resins would cause the glue to dry quicker and stronger with this wet wood.
According to Michael Dresdner in volume 1, issue 2 of the Woodworker's Journal E-zine, “White and yellow adhesives are essentially the same thing - PVA (polyvinyl acetate) - and are therefore fully interchangeable. Yellow glue was introduced with a bit of coloring in it to distinguish it as a higher quality product. Typically, it has a higher solids content, is a bit thicker, and often has a faster tack time. None of these issues has much of anything to do with strength, but rather of handling properties. Thicker, faster tack yellow 'glue' does not run as much and lends to easier assemblies in some cases.”
Marc Adams prefers white glue because of the extended open time, and because it dries clear, where yellow glue dries yellow. When applying glue to a large area, or to a complex area like dovetails, the extra open time allows you to work at a comfortable pace without worrying about the glue setting up before you get things assembled.
The idea of more working time appealed to me, so I bought a small bottle of Elmer's Glue-All and used it to assemble the doors on the entertainment center I am currently building. As expected, I really liked the extra open time, and the fact that it dried clear was appealing as well. Since I just bought a gallon jug of Titebond, I'll have to wait to switch to white glue. But once it's gone, I’ll be a “white glue convert”. I also learned that all PVA glues have a shelf life of about year. So when you buy a bottle, mark the date that you open it on the bottle with a pen and throw it away after a year.
A Sticky Subject: Glue
Created by:
Sam Conder
- Published: 10-27-2002, 12:01 AM
- 0 comments
Categories
Article Tags
- BT3x00 (72)
- bt3000 (5)
- bt3100 (2)
- cordless (1)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by
twistsol
While digging through the old site files, I ran across this PDF file that had no information other than a number of pictures. The file title was McConnell.pdf I can't find any reference to it on the site....-
Channel: Miscellaneous
by
twistsol
function calcFenceAngle() { coveWidth = thisForm.elements['coveWidth'].value; coveDepth = thisForm.elements['coveDepth'].value; Blade = thisForm.elements['Blade'].value; // document.write("coveWidth = "+coveWidth+"coveDepth = "+coveDepth+"Blade = "+Blade+""); preValue1a = Blade - coveDepth; preValue1b = preValue1a * preValue1a; preValue1c = Blade * Blade; preValue1d = preValue1c - preValue1b; preValue2 = Math.sqrt(preValue1d); preValue3 = 2 * preVal...-
06-17-2015, 07:48 AM -
by Jim FryeFor many years, I have been using the power switch on my BT3000 to turn on the shop vac as well as the saw itself. My old shop vac was a low powered unit and together with the BT3K’s motor didn’t exceed the 20 amp. rating of the contacts in the switch. That all changed when I replaced the shop vac with an industrial model of Shop Vac. After several weeks of forgetting to turn on the vac when I started the saw, I knew I had to go back to the automatic method of starting the dust collector. Fortunately, Sears had the solution for this problem. They have a $20 tool triggered outlet device that plugs into a standard duplex outlet and provides two outlets that are switched on when the tool that is plugged into the primary receptacle on the device is turned on....
04-29-2015, 08:10 AM -
by staffOriginally Posted by Ray Girling in the category Miscellaneous
Kickback – The Nightmare Explained Most tablesaw owners dread kickback without necessarily understanding what it is and more importantly, what causes it. Knowing that it involves a piece of stock coming back towards you is fine, but as with most technical matters, once you understand how and why it happens, you’ve got much more chance of preventing it. These words and pictures are an attempt to get back to basics and de-mystify the subject. ...-
by Sam ConderA Virtual Tour of the Indianapolis Woodworking Show This weekend, I made my annual trek to the Indianapolis woodworking show. I have been going every year for the past five years. This year, I was finally fortunate to have a bit of extra money and was able to attend one of the all day seminars. Below are some photos I took specifically for this site. I wanted to give those of you who are not able to attend the shows a glimpse of what they are all about. I struggled with the decision of which w...
04-29-2015, 04:49 AM -
by Sam ConderIn a “Fundamentals of Woodworking” class I attended taught by Marc Adams at the Indianapolis woodworking show, he stated that he uses ordinary white glue instead of yellow glue for the majority of his joinery. I decided to do a little research on the two types of adhesives and was surprised by what I found. White glues like Elmer's Glue-All are polyvinyl acetate (PVA) based adhesives. Yellow glues like Pro-Bond and Titebond are aliphatic resin glues, which are merely PVA adhesives with additives t...
04-29-2015, 04:39 AM -
The SawdustZone Statistics
Topics: 61,768
Members: 20,854
Active Members: 23
Welcome to our newest member, Eztravia_US.
What's Going On
There are currently 4057 users online. 1 members and 4056 guests.
