Ryobi BTS15 Operator's Manual
  • Ryobi BTS15 Operator's Manual
    This is an Adobe PDF file that contains the English language version of the BTS15 Operator's Manual. WARNING: This file is 1.16MB and will take a while to download over slow connections. I highly recommend right-clicking the "Download" button below and select "Save As…"
    BTS 15 Manual:
    BTS15_290_eng.pdf
      Posting comments is disabled.
    Latest Articles
    • Screw friction products EZ-Grip and Screw Grab?
      by LCHIEN
      I was reading an article about fasteners the other day.
      They mentioned a couple of products I had not heard of before:
      EZ-grip and Screw Grab
      Apparently if you have a screw that you have a hard time engaging like a worn Phillips, a drop of these products will increase the friction between the screw and the driver 8X it is claimed so that you can back out the screw.
      You can find them both at Amazon.
      Not cheap 5 oz of EZ-GRIP is $20; 1/2 oz of Screw...
      04-07-2022, 10:58 AM
    • A Cure for the Shim Problem on the Ryobi BT3000
      by twistsol
      Originally written by Norm Havens and re-posted here.
      Editor's Note: The site where this article appeared originally is now gone. I had this article saved as a .pdf file from years ago and resurrected the article from that.
      December 3, 2000 I must be totally star-crossed this week . . .
      "Trouble comes in threes," didn't someone say? This week I've already dinged the blades of my new planer, nearly dropped my router from the accessory table, and now...
      08-29-2018, 11:21 AM
    • Ryobi BT3000 and BT3100 Manuals
      by twistsol
      The manual from the old site is out of date and many of the links in it were broken. The downloadable .PDF manuals are attached below.
      11-21-2017, 09:23 AM
    • Lonnie's No Measure Alignment procedure
      by Lonnie in Orlando
      Hi Guys - I haven't been on the forum much lately ... I bought a '55 MGTF-1500 that is taking up space, time, and money that is(was) used by my woodworking shop. The car has a wood frame beneith the body panels, so I guess it counts as woodworking. Thanks for resurrecting my No-Measure alignment thread. I see that it has lost some of the attachments. So I reposted it below. Note - there are a lot of good ways to adjust a BT3K or any other table saw. This is the one that I found is best for...
      04-29-2015, 09:49 AM
    • BT3K Shim Replacement
      by Black wallnut
      Since it seems time for my semi-annual maintenance and due to several posts asking how to lately I deciced to take pictures during mine. Keep in mind this is specifically for the BT3000 only.
      Step 1: double un-plug saw at outlet and onboard outlet. Remove throat plate, Sharkguard, Big dog clamp, and splitter (or the stock POS []). Remove blade and spacers.
      Step 2: remove left side cover and dust shroud.
      Step 3: remove the four...
      04-29-2015, 09:41 AM
    • BT3000 To 3100 Shim Upgrade
      by crokett
      Upgrading the shims avoids the issue of the BT3000 shims dropping out and causing the blade-raising mechanism to bind.
      Before you begin:
      Call Ryobi technical support at 1-800-525-2579 with the serial number from your saw to
      verify that your saw is eligible for the upgrade. Some earlier BT3000s are not.
      ‘Right’ and ‘Left’ designations assume you are starting by looking at the front of the saw.
      These instructions assume a stock
      04-29-2015, 09:33 AM
    The SawdustZone Statistics
    Topics: 61,772   Posts: 561,933   Members: 20,862   Active Members: 27
    Welcome to our newest member, cian.
    What's Going On
    There are currently 4864 users online. 0 members and 4864 guests.
